Sqweaky steering
Old Dec 19, 2007 | 08:49 AM
acuratl_2nr's Avatar
Sqweaky steering
I keep hearing this aweful sqweaking noise when I turn the steering wheel and I have no clue what's causing it... I can hear the noise clearly from inside and I know people can hear it twice as loud outside because when I make turns in a parking lot people turn around and stare The noise just started recently when we started having cold weather... I didn't have time to check out the car yet... I am certain that it has to do with steering because the noise is continuous when I turn my wheels...Anyone know what it could be?
Old Dec 19, 2007 | 09:00 AM
Dicorp's Avatar
maybe the PS belt is worn out or the pump is going
Old Dec 19, 2007 | 09:07 AM
I'm gonna check the ps belt today, I had taken it off to change my alt belt, maybe it's not tight enough
Old Dec 19, 2007 | 09:15 AM
Dicorp's Avatar
that could be it
the noise is really loud right?
Old Dec 19, 2007 | 09:28 AM
Originally Posted by Dicorp
that could be it
It's not a loud whine when the car is on its a sqweaking noise when I turn the wheels...
Old Dec 19, 2007 | 10:58 AM
dragon084's Avatar
1999 CL3.0
i get teh same shit
Old Dec 19, 2007 | 11:06 AM
Originally Posted by dragon084
i get teh same shit
shit, that means it's not caused by the cold weather
Old Dec 19, 2007 | 11:25 AM
Alperovich's Avatar
6spder
does come from the steering column? i know chevy's have a huge problem like this. i think its caused by worn bushings in the steering linkage (from the steering wheel to rack)
Old Dec 23, 2007 | 06:04 PM
Turned out to be a bad lower ball joint on the passenger side... the boot wasn't torn or anything it was just out of grease inside and making that awefully annoying noise...
Old Dec 26, 2007 | 06:54 PM
Mr_Xclusive808's Avatar
Check your p/s belt to make sure it's torqed right. Then check your p/s/ fluid to see if its low. Then check the lines to see if there are any leaks. Place a cardboard bow or something under the carand then turn the wheel, If it leaks it should spray on the box. But it's probably just low on fluid.
Old Dec 26, 2007 | 07:56 PM
Thanks for the input, but it turned out to be a bad lower ball joint...
Old Dec 27, 2007 | 01:32 PM
Good to hear you got it fixed bro!!
Jul 16, 2017 07:33 AM
spudweb
May 22, 2016 02:39 PM
CL-S progression 01
Jan 26, 2016 04:15 PM
Euro4gen
Dec 12, 2015 03:14 AM
