Speedo flick
Old Jan 2, 2008 | 01:59 AM
monstui's Avatar
3rd Gear
Speedo flick
Hello.
Acura cl3.0 97 AT
my speedometer every now and then flickers, dropping to zero then back up to speed. sometimes this happens, sometimes it doesnt. sometimes it doesnt work at all. untill i come to a stand still, and start move again, then maybe it'll work or not. vary rare that it doesnt work.
I've done some reading and want to know if i would be able to change the sensor on the transmission. or where exactly it would be. DIY as opposed to getting it done in the shop.
thnx
Old Jan 2, 2008 | 09:30 AM
young03's Avatar
its JDM yo!!!!!!!!
get ur charging system checked out could possibly be ur alternator or battery problem. but if u look at my thread need help asap there is a link to show u were the sensor it at on our tranny
Old Jan 2, 2008 | 12:29 PM
AznX TL's Avatar
where is....
sounds more like vss.
Old Jan 2, 2008 | 01:53 PM
monstui's Avatar
3rd Gear
by the charging system, alternator and battery, you mean the electrical system of the engine?where can i find your thread?
vss ... speed sensor.
Old Jan 2, 2008 | 02:02 PM
monstui's Avatar
3rd Gear
found your thread, but no link.
Old Jan 2, 2008 | 02:36 PM
AznX TL's Avatar
where is....
vss= vehicle speed sensor
and he was referring to this link http://www.acuraautomotiveparts.org/...s=&view=normal
Old Jan 2, 2008 | 04:39 PM
young03's Avatar
its JDM yo!!!!!!!!
i tried removing my vss sensor this past weekend it was a bitch to get off there is one bolt that holds it in remove that and u should be good
Old Jan 2, 2008 | 06:46 PM
DoubleSh0t's Avatar
When my alternator was failing/failed, I had the exact same problem - and our cars are notorious for alternator failures. You can check to make sure you're getting at least 13 volts out of it, if not you know it's on the way out.
Rob144
Sep 21, 2015 08:18 AM
acuraST
Sep 17, 2015 02:31 AM
02tljj
Sep 11, 2015 12:37 PM
