RPM UP/DOWN help
RPM UP/DOWN help
98 CL 3.0 parked not running for over a year. Ran the engine until most of the gas was out changed the fuel filter put injector cleaner in and filled tank up.
Now the rpm go up/down in park and while in drive rpm are higher then before.![Annoyed](https://acurazine.com/forums/images/smilies/annoyed.gif)
Could this be a sensor or gas and suggestions thanks
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Sounds like a sensor, could be the TPS or IACV
Seafoam didn't work here is a youtube on what the car is doing.
hxxp://www.youtube.com/watch?v=OwLgffl2mjU
replace hxxp with http.
Please let me know what u think it is and if there is a guide on how to fix it thanks
no because It has been on for years it would go on and off for no reason. I took it the dealer and they kept saying it was the gas cap not being tighten.
So I have a feeling it would be a false but tomorrow I will take to see if I can get a code.
I am leaning towards IACV but can't find a good sticky on how to clean it out
I am guessing you didn't take anything apart while it sat did you? the reason I ask is anytime I see something like this the first thing that comes to mind is vacuum leak somewhere. I have not had very many computer cars with all the sensors so I could be way off on this but still figured I would ask if anything that has a seal had been removed for anything at all or loosened while it sat for so long
DerrickW
11-15-2015 05:52 PM
