Remote Start
Old Jan 30, 2006 | 04:28 PM
Bigpimpin18's Avatar
Soon to be H22 turbo!
Remote Start
ok so I finally hooked up the remote start part to my car now. I go to hit the remote start button, the engine turns on and immideatley turns off? wuts up with that. I read the manual and it says if your car has an immobilizer than the immobilizer will cut the fuel and/or spark. So my question is do we have an immobilizer and if so how do I get it so it can run??
Old Jan 30, 2006 | 10:57 PM
xJRocKx's Avatar
Wow i get to finally post about something i MAY know about. I had a similar problem with my remote start. My first question would be does the motor actually crank. If not you may be running into something similar to my problem. I had a bulb in my tail light that was not functioning right. What happens, or at least how it was explained to me, the car begins to start, but because the lights are one circuit the car thinks the brake pedal is pushed and then turns its self off. Not sure if that made any sense at all to you or if that will even help ya out. But all I had to do to fix mine was replace the bulb in my taillight. Hope this at least helps some.
Old Jan 31, 2006 | 11:00 AM
no, cuz I don't have my brake shutdown wire wired to my brake switch, it's wired into a relay on my clutch wire. But yes it cranks, fires up, than 5 seconds later it dies.
Old Feb 22, 2006 | 10:39 AM
The problem was that there is a remote start activation wire, the schematic said to wire this to a switch than ground it. Well i just grounded it cuz I didn't want a switch. Well I guess the wire is able to start the car with a push-button, so alls it was was a simple little wire that turned the car off.
oyayjoe
Jan 1, 2019 10:17 PM
oyayjoe
Sep 12, 2015 04:40 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
jordanboi
Sep 5, 2015 01:33 AM
datadr
Sep 2, 2015 06:46 PM
