Rec Repairs for Acura CL 1998. Considering additional inspection
Hi. Very much enjoy the CL 1998. It's at 140K miles. I'm doing exhaust currently. A few other items recommended. Are below critical. I'm getting another inspection (full) but looking for a mechanic familiar with vehicle class and Honda/Acura. Should have whole time of ownership. Can likely do pulley/belts soon. Thanks for considering. I can report back after second inspection. Just have to find right team to work on it. Any advice on determining mechanic appreciated. These were from Acura service center (has been helpful, they lost their top mechanic and rec doing exhaust possibly other elsewhere)
OIL LEAKS AT REAR ENGINE SEAL.
recommended
REC. REPLACING A/C COMPRESSOR COMPLETE ASSEMBLY
REC. REPLACING CRANKSHAFT PULLEY AND DRIVE BELTS. CRANKSHAFT RUBBER DAMPER IS CRACKED PULLEY WOBBLE/ NOISY AT IDLE.
REC. REPLACING POWER STEERING GEAR BOX COMPLETE ASSEMBLY WITH INNER AND OUTER TIE RODS. P/S RACK IS LEAKING.
recommended
Excelerate
30
Nov 15, 2005 12:09 PM
