Poor Cooling
Poor Cooling
Hello to everyone. I am hoping I can find an Acura guru on here. I have a 97 Acura 3.0 CL and the ac is driving me crazy. Long time ago the ac was perfect up until my garage informed me I had a restriction. The expansion valve and receiver/drier was replaced and ac topped off. I tolerated poor performance for years until I decided to replace the same components again years later only to end up with the same results. The last time I replaced the components and my Honda dealer recharged the system. They indicated that pressures were within specs with no leaks. I am wondering what else it could be. I have to run the system on 60 and it never really gets cold. Cooling fans working, correct amount of Freon, and good pressures. Any help would be appreciated
I'm no refrigerant expert, but it's difficult to argue, with the R134 performance, my a/c system produces! The Dealer, that re-charged OP system, should be able to advise, exactly which refrigerant was used. From an A/C novice's standpoint, I don't understand, why, any specific (grade) freon, would fail to produce satisfactory results, when used in a ( properly) operating system. In the past, when Manufacturers switched over to R134, from R12, friends suggested, R134 was no where near as efficient, as R12! WRONG.
dd1818
Nov 8, 2003 10:27 AM
ddubois
Sep 25, 2003 07:54 PM
