NOT the same old DRL problem !
Old Feb 20, 2008 | 07:59 PM
WolfBoy's Avatar
Flamenco Blk 3.0CL PREM
I had the infamous DRL problem and re-soldering solved the issue for about 4-5 months then one day it stopped working and the dash is a xmas tree and the left high beam doesnt turn on .. i changed the module with a friends module that i have happened to re-solder as well, and it worked just fine. I tested mine on his car and it worked just fine as well. i checked the engine fuse box and the one by the driver's foot and the fuses are fine .. what am i suppose to do now ?!
Old Feb 21, 2008 | 12:43 PM
WolfBoy's Avatar
this is driving me insane ! help plz.
Old Mar 3, 2008 | 02:06 PM
WolfBoy's Avatar
no one !!!????
Old Mar 3, 2008 | 03:08 PM
johnnyblaz3's Avatar
my drl is always on and i dont think ima fix it.. a light wont hurt right?
Old Mar 5, 2008 | 02:06 PM
WolfBoy's Avatar
no if it was just the dash light i wouldnt mind but my left high beam does not work when the DRL module is not functioning.
thats a problem since i drive alot at night on country roads ..
Old Mar 5, 2008 | 05:15 PM
monsieur le technologue's Avatar
You seem to have a problem with the high beam not with the DRL I have to check but I think that the DRL can come on if a high beam is burn out. In your case i'm sure that you already have checked your light but you may check if you have power from your DRL to this high beam and if you have power next to the module and not at the beam it can be a short cut between
Old Mar 7, 2008 | 10:37 AM
CRXZC's Avatar
Okay - kind of off topic - but I'm having the regular DRL problem.
What is the easiest way to get to it, what does it look like, and do I need a CL/Accord specific module, or are all Hondas the same?
If I remove the relay completely will I have no lights, or just no DRL's? Currently I have no passenger high beam and no DRL...
Thanks!
Old Mar 8, 2008 | 11:17 AM
WolfBoy's Avatar
hey dude .. tanx for the info ..
i never thought of it that way .. i guess if DRL is not functioning the high beam has problems then the other way around would make sense .. i actually didnt check to see if the high beam is bulb is ok or not ..
would u mind checking to see if drl would come one if high beam is burnt out ?
tanx man.. dont know where i could get this info !
Old Mar 8, 2008 | 11:56 AM
Yeah I confirm that. I refer to the page 50 of your owner manual ''If it come on at any other time , it means there is a problem with the DRL. There may also be a problem with the high beam headlight '' If you don't have checked your bulb you should begin your research there .
Old Mar 8, 2008 | 12:51 PM
WolfBoy's Avatar
this all makes sense now since the last time the DRL module crapped out on me the passenger side highbeam stopped working and now its the driver side thats not working .. i cant believe i didnt think of this ..
tanx alot bro .. i appreciate this and will let you know how it goes ..
Old Mar 10, 2008 | 10:05 AM
WolfBoy's Avatar
hey monsieur le technologue,
my high beam bulb had exploded ! that was the problem .
tanx for ur tip buddy ..
Old Mar 11, 2008 | 01:46 PM
Goood!
SidhuSaaB
May 30, 2020 12:40 AM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
