my lights dim with my turn signal...
when i turn my turn signal on, all my lights, headlights and interior lights dim slightly with the beat of the turn signal, could this be my alternator going?
Wrong! I have been having the same problem too. Ive changed bat. and alt. neither fix it.
Check out this unsolved post: https://acurazine.com/forums/showthr...dimming+lights
So I am in the process of trying to get this fixed from what i gather in that post.
Oh I understand that its not always wrong thats why I changed my bat and alt first but if you read the post that I linked to then you will see that this problem he explained is not the Alternator it is the ELD going crazy. There is a 99.9% chance that this is his problem and not an alt. since he explained the problem exactly like everyone else with the problem has and even I have and it was not our aLts. it is the ELD.
But this is about the best as I got from those post:
Thanks,
smgtech.
"at night headlights dim when turn signals on at idle Tech line #877117 checked charging system battery OK called Tech line Removed #2 pin white green wire from connectorC131 fixed problem."
"Found virtually every load in the vehicle receiving varied voltage input when blinkers were in use. Inconsistent voltage causing any light to have a slight strobe or flash effect. Determined fault to be present in every circuit suggesting a charging system error. Examined the "ELD" (Electrical Load Detector). Found ELD supplying PCM with varying and inconsistent commands/inputs, thus forcing the PCM to constantly switch the alternator from high to low output, causing a vehicle wide condition. Suspect after market bulbs of varying and difference from stock resistance causing an average amperage draw slightly different than stock. The new average draw falls in a gray area of the ELDs logic mapping software, making it difficult /impossible for the ELD via PCM to correctly command high/low operation at idle. If loads are added/taken away, or RPM brought up, problem diminishes. Bypassed ELD to create an always high condition/command for the alternator. This will have zero adverse effects."
smgtech.
I'm currently getting a mechanic to look at it and when i get it fixed I will let you know hopefully with pics. I really feel someone should have already done a DIY on this because the car is 10 years old and so many people have had the same problem!
who wants to go in together and get this manual?
http://www.helminc.com/helm/product2...EG2FUBHSF02R33
Well there is a plug on top of the alt. it has 4 little wires in it. the bottom left wire if hooked to the pos. bat post will give the alt. an always on connection...I suppose if you wanted to you could do this but i say (bad mpg) so no way...the real question is there a way to fix the ELD? I might have to take it to an Acura Service center and fork up 115 and hr for electrical.
For those who are looking at replacing there ELD (Electric Load Detector) which might be the leading indicator as to why your headlights are flashing when your turn signal is engage, check out this post;
http://www.ephatch.com/forum/showthr...rt-%28P1298%29
mada51589
Jan 9, 2025 04:40 PM
rockyboy
Aug 4, 2024 10:35 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
where is this wire
