Knocking sound. what could this be?
Old Dec 20, 2013 | 01:30 PM
KrAcura97's Avatar
I have a 1997 acura cl 3.0 with 170k miles and recently I have noticed a knocking sound coming from the pulley side of the engine. The sound only occurs about 10 mins after warming up. the sound doesn't seem to be metal on metal and is not a pinging noise. It sounds more like a dampened knock. It is most noticeable at the lowest rpms and doesn't get louder as it is revved but just speeds up. I took off the alternator belt thinking it could be a loose pulley but no luck. the timing belt and water pump was done at about 150k miles if that helps. anyone have any ideas of what this could be? Thanks
Old Jul 1, 2014 | 09:09 PM
ModMechanic's Avatar
8th Gear
t-belt tensioner????? better pull the timing cover up and see whats going on
Old Jul 2, 2014 | 07:22 PM
Showmeyourtints's Avatar
How are your motor mounts?
Old Aug 28, 2014 | 07:17 PM
bjmcconnell's Avatar
Same
Im having the same problem with mine I just found out today, please help.
lanechanger
Oct 13, 2015 10:56 AM
rockyboy
Oct 2, 2015 10:45 PM
DerrickW
20
Sep 27, 2015 02:45 PM
STL TL-S
Sep 23, 2015 08:52 PM
rklatzkin
Sep 23, 2015 04:08 PM
