car turning off while driving?
Old Jan 8, 2010 | 03:16 PM
mushroom king's Avatar
5th Gear
my acura 2.2 cl is turning off while im driving it, so it coasts and i have to turn it back on while driving it, which is pretty dangerous. it does it every 1 - 10 minutes or so of driving... the battery light and oil light comes on once it shuts off. I'm not sure what it could be..
Old Jan 8, 2010 | 03:40 PM
JS + XES's Avatar
I drive a Subata.
oh wow that's pretty dangerous yeah.
transmission failure?
Old Jan 8, 2010 | 03:45 PM
dallison's Avatar
registered pw
can you have the codes read? and does it start right up after it shuts off?edit: i see it does
hell, in the olden days i would trade it and hope that it wouldn't act up at the dealer.
Old Jan 8, 2010 | 04:00 PM
NSXNEXT's Avatar
Sounds like your ignition switch is bad. Happens a lot on the 2nd gen TL.
Old Jan 8, 2010 | 04:08 PM
spurfan15's Avatar
Seems like it could be some electronic or ignition switch problem. Either way that's very dangerous because you will lose your power steering and power brakes very soon after the car turns off.
Imagine that you're headed toward a potential accident and need to swerve and/or slam the brakes to avoid it, and right at that moment, the car turns off. You slam the brakes but they quickly become useless, and the steering wheel becomes almost impossible to turn. You may not have time to react by turning the car back on and then performing emergency maneuvers. The same could happen in a sharp curve and screw you in the same way.
I would deal with this immediately if you want to continue use of that car.
Old Jan 8, 2010 | 04:09 PM
ifirahse's Avatar
SlammedOnKonis
Happened to me in my 04 A4 right before I returned it...wasn't fun.
Old Jan 8, 2010 | 04:11 PM
juniorbean's Avatar
Welcome to the forum!
Being that your topic is about a car covered by one of our model specific forums, I am going to move your topic to the CL forum. There you will be able to get answers from fellow First Gen CL owners!
Again, welcome to Acurazine!!
Old Jan 8, 2010 | 04:31 PM
mitch14's Avatar
CL in lawnmower status
is your car currently idleing abnormally low, i had this same problem with my caddy, the revs would fall so low that the engine would just die.
Any service done recently or anything like that?
i'd say for idleing lower than normal could be vacuum lines being unhooked as that was my culprit, but besides that i have no cl specific suggestions
some of the other guys in the forum may have more info for you
good luck
Old Jan 8, 2010 | 04:51 PM
OttaWacK's Avatar
less n00bin more g00glin
How long has this been happening? Could be faulty charging system like your alternator.
Old Jan 8, 2010 | 06:50 PM
IllGottenGains's Avatar
Sounds like the ignition switch might be the culprit. Check to see if your car has a recall for the ignition switch. It was a common problem on some of the 97-99 Accords and CL's. Not every car falls under that recall. Have a dealership run you VIN number.
Old Jan 8, 2010 | 09:56 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
It's your ignition switch, there was a recall on this
Old Jan 9, 2010 | 10:06 AM
97'CL2.2's Avatar
this same thing happened to my 91 Accord around the 200K mark. turned out to be the distributor...start w the recall tho its cheaper
Old Jan 10, 2010 | 05:25 PM
mitchflorida's Avatar
If it only happens when the RPMs are low, or when you are coasting to a stop, it could be your car needs a tune-up. I had the same problem and they adjusted the idle valve and changed out the spark plugs, and it runs much better.
Old Jan 25, 2010 | 12:49 PM
JRoc99Cl's Avatar
Mushroom, like others have said have your ignition switch checked. Is your check engine light on? Run codes and advise us on what you find...
Old Jun 4, 2010 | 04:12 PM
paco99cl's Avatar
jdm is my anti-dub
hate to bring back an old thread but i been having the same problem. its the igniton recall i called up my local acura dealership they ran my vin and goin in on thrusday next week ..... just make sure u tell them that its very dangerous and you dont feel safe driving it ......but the vehile has to show no history of being fixed threw recall or open campaign thats open on your vin number so hope that your igntion hasnt been changed b4 you had the cl in your hand and goodluck with the recall they will try to not fix it jsut so they dont lose money in anyway
Old Aug 13, 2014 | 06:48 PM
JACrist's Avatar
8th Gear
Mine had similar problem (98 2.3 CL 5-spd). Turned out to be ignition switch.
Old Sep 4, 2014 | 06:10 PM
intriguecl's Avatar
5th Gear
happened to me, check your ignition switch, play with the key while driving in a safe place and see if it dies,
peti1212
ILX
22
Jan 5, 2022 05:14 PM
Feb 25, 2020 09:57 AM
divac
Aug 29, 2018 10:13 AM
