Head unit problem
Old Aug 2, 2006 | 08:46 PM
MFlo's Avatar
Head unit problem
I have a 98 3.0 with bose, and I was replacing the stock receiver with an Alpine CDA-9856 tonight. The first couple times I turned it on, it was working fine (although I hooked up the blue wire (power antenna lead) from the head unit to the blue wire of the adaptor harness instead of the blue-white wire, but I fixed that).
However later on, the head unit stopped turning on and it seemed like it was getting no power at all. I checked all the wires and they were connected correctly. I also plugged the stock unit back in and the alarm light lit up like normal. The fuse isn't blown. Does anyone know what might be the cause of the problem? I think in the beginning, I forgot to plug the antenna jack into the unit, could that have anything to do with it?
Old Aug 3, 2006 | 06:02 PM
GeoffMayfield's Avatar
Did you check your ground. It could be bad or not making a clean connection.
Old Aug 4, 2006 | 08:39 AM
MFlo's Avatar
I fixed it, it was a blown fuse after all (I don't know how I missed it ). Thanks though.
Feb 25, 2020 09:57 AM
Soul_Deamon
Nov 13, 2018 04:44 PM
jpadilla
3G RLX (2013+)
Nov 18, 2017 07:13 PM
1lowtc
1G RDX (2007-2012)
15
Nov 19, 2015 10:52 AM
tmux
Sep 21, 2015 05:11 PM
