engine swap!!!!!
Old Apr 12, 2010 | 03:12 AM
TexasTony6777's Avatar
engine swap!!!!!
I have a '97 2.2cl with a stock motor and auto-trans. Looking to swap out to a Prelude 2.2L DOHC VTEC with 5sp manual trans. I know I need all the extras to install, such as cluth master, shifter, ecu, and motor mounts. Do I need to cut anything?
Old Apr 12, 2010 | 08:15 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
You should not need to cut anything, the h22 will use the same mounts, wiring will be your main issue
Old Apr 12, 2010 | 12:01 PM
f22vtec's Avatar
pics?
Old Apr 12, 2010 | 10:51 PM
DaInFaMMuS1's Avatar
Do a SEARCH. It's been covered numerous times. U can use your stock harness, and it bolts right in, no banging on the engine bay unless you have a Skunk2 intake manifold or a supercharger.
As for the tranny swap, thats gonna require some cutting/fabbing for the 3rd pedal and clutch master/slave and linkages probably.
Nathan Allan
Jul 1, 2023 06:33 AM
dirtyspitshine
Jan 3, 2023 08:23 PM
LECKEY73
Feb 22, 2016 01:32 PM
justin7779
Dec 25, 2015 10:33 PM
02tljj
Sep 11, 2015 12:37 PM
