Egr Flow problem..fixed everything to no avail. Help please!
Old Jul 15, 2011 | 11:26 AM
cjleveille's Avatar
I have the inefficient egr flow code on my 99 Acura CL. It has 240,000 miles on it, but runs great. I have took the following steps to get this code off, and nothing seems to work. First I seafoamed the car to no avail. Next I replaced the egr valve to no avail. Next I removed the intake and cleaned the EGR port(it was clogged pretty bad). I thought this might take care of the problem, but after reconnecting my battery and driving about 5 miles, it came back on. I am at a loss, any ideas of what it could be? Thanks for your help. I also replaced the PCV Valve just incase it was an issue.
Old Jul 15, 2011 | 01:05 PM
Project_CLean's Avatar
MMkay.
check vacumn hoses; does it come on at certain times?
Old Jul 15, 2011 | 01:17 PM
cjleveille's Avatar
99' cl 3.0
The light has been on for a couple of months. One of the suggestions at the parts store was vacume line leaking or clogged. But I am not sure which lines are the vacume lines or which one will effect the egr flow.I know where the PCV vacume line is, thats about it.
Old Jul 15, 2011 | 02:31 PM
MMkay.
follow both from egr; see what you can find.
Old Jul 15, 2011 | 02:50 PM
cjleveille's Avatar
There are no lines that come off the egr valve that I see. I am wondering if the plug that goes into the egr valve is bad. I am assuming I can just check it with a multi meter. All the lines around the motor that are visible seem OK. Stumping me right now. Thanks for your help PC! Much appreciated.
Old Jul 15, 2011 | 08:19 PM
cjleveille's Avatar
Cool
Yea........I got nothing! Plug seems to be working just fine, I might have to take it in and get it looked at! NOT what I wanted to do! Anyone else have any ideas about which vacume hose could cause egr flow to be bad?? Computer maybe?? Is there a celanoid some where?? Fuse?? Any ideas/thoughts on this matter?
Old Jul 16, 2011 | 10:55 AM
MMkay.
how does it run if you dont mind me asking? rough idle? if so; get some brake clean from an auto parts..whilee the car is runnin spray just a little around vac hoses..listen for change in idle..fluctuation and so forth.. check that vacumn hose if it sounds like it affected it.
Old Jul 16, 2011 | 09:33 PM
97'CL2.2's Avatar
are you sure you dont have multiple codes?...bc then it would make sense ur CEL is still on after taking care of the EGR system
fifer16
1G RL (1996-2004)
Nov 22, 2024 07:07 PM
CL-S progression 01
Jan 26, 2016 04:15 PM
hashbrown
Sep 29, 2015 12:13 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
prbori
Sep 27, 2015 01:37 AM
