distributor problems?
Old Apr 19, 2009 | 04:30 PM
a2ndragoon89's Avatar
joe rocks c2s :D
hey guys ...
so i was driving on the road, and all of a sudden my car just shuts off on the highway...This is like...the 4th time it has happened. Like i'll be driving and i go into a stall for some reason.
It's in 5th gear basically and it just stalls while i drive. I mean i can drive normally, but it's dangerous if i'm on a bridge where i cannot pull over or in an area that has no way for me to stop.
Also, when i start the engine up it starts up fine. My check engine light goes up and stays on. I recently replaced my clutch, and told my mechanic about this, but he hasn't fixed it...I've been told that it could be my distributor that needs replacement or something, but i wanted to see if you guys had any experience in this.
Another key note...the tachometer idles under 1000rpm. is that bad?
distributor FTL?
Old Apr 21, 2009 | 12:05 PM
TexasHonda's Avatar
Do the dash lights (CEL, Alt) stay off when this happens? If yes, then the ignition keyswitch assy is the fault and nothing to do w/ distributor.
If dash lights come on (as they should), then ignition or fuel delivery is the problem.
I would suggest getting the CEL fault code (autozone or other auto parts will check for free). It may provide a clue to your problem.
good luck
Old Apr 21, 2009 | 06:01 PM
joe rocks c2s :D
all lights stay on. i just got the distributor replaced, testing it within the week
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
