dash don't work.
Old Jun 28, 2006 | 03:33 PM
zippy33's Avatar
dash don't work.
Hi.About 2 years ago my dash went out,speedo-gas gauge-oil-tach,everything stopped working.I enquired about getting it checked and the acura dealer said there's 5 miles of wiring and at $85 an hour it could get costly.I left it and 2 weeks later everything came back.
It happened again today.Everything stopped working.
Has this happened to anyone else?
Any ideas?
Car is a 1997 acura cl 3.0 liter.About 120,000 miles.
Thanks.
Old Jun 28, 2006 | 07:10 PM
Nakamichi's Avatar
~[ô¿ô]~
Hasn't happen to be, but try the following:
Check the following fuses:
Under-Hood Fuse/Relay Box: No15 (100A); No16 (50A)
Under-Dash Fuse/Relay Box: No9 (7.5A); No4 (7.5A); No1 (10A)
Check the connection to the gauge. There should be three harnesses on the back of the gauge. Make sure this is tightly secured.
Make sure the ground for those are secure. One of them is behind the right kick panel connected to a main harness. The other is on the under the middle of the dash on the left side.
Old Jun 28, 2006 | 07:54 PM
zippy33's Avatar
fixed
I disconnected my battery for 2 hours,hooked it back up and everything works again.Must be a short somewhere.I'll check out the things you suggested.
Thanks.
Old Nov 17, 2011 | 10:51 AM
zippy33's Avatar
it ended up being in my ignition,where i put the key in.changed that and it's been fine ever since.
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
04tler
Sep 10, 2015 01:13 PM
sputik
Sep 7, 2015 01:40 PM
