Clutch master cylinder replacement issue
im replacing my clutch master cylinder, and im running into a issue with the replacment. the last step i did was remove the cotter pin from the clutch as pedal as stated in a DIY guide i found.
but my problem is that i cant find the 2 master cylinder mounting bolts. if anyone has any tricks or advice to make my life easier with this replacement. thanks
cycdaniel
Dec 17, 2019 10:58 AM
