The CL broke down
Old Nov 17, 2010 | 08:21 PM
ma777's Avatar
The CL broke down
Car started making a knocking sound under the black cover on the right side of the engine. I assume its the timing belt. I guess it tore. Power steering then went out. I wasnt to far from home so i tryed driving it home. I was driving home put it in nuetral and noticed my rpms were at zero. I guess it finally broke then. I parked it in the middle of the street. Had some old lady help me best as she could. I pushed it up a hill while its raining on me. Im slidin all over. What a shit day.
I guess i just need to buy new belts and hope i didnt mess anything else up while driving it home.
Old Nov 17, 2010 | 09:18 PM
ma777's Avatar
after some research im pretty sure its the camshaft pulley belt. Ill know more tomarrow when i get it home.
Old Nov 18, 2010 | 08:57 AM
TAco23's Avatar
fingers crossed you didnt really "F" up you motor. valves can get damaged, rods bent even pistons damaged is possible when driving with no belt like you did.
Old Nov 18, 2010 | 09:56 AM
97'CL2.2's Avatar
this happened to my DSM a while ago...had to put on a whole new head bc nearly all the intake and exhaust valves were f'ed. hope this isnt the case w u...keep us posted
Old Nov 18, 2010 | 02:21 PM
Gigolo's Avatar
1999 Acura CL 2.3
brutal
good luck though
Old Nov 18, 2010 | 02:24 PM
Aman's Avatar
Your Friendly Canadian
Well I doubt it's the timing belt unless you were seriously late on that bit of maintenance, in which case, a lesson well learned.
Old Nov 18, 2010 | 02:32 PM
ma777's Avatar
I hope my engine isnt F'ed either. But if it is h22 is gunna go in it. My dad will have to be on board now if my engine is completely screwed. Ill have it home tonight and know more then.
Old Nov 18, 2010 | 04:00 PM
ma777's Avatar
Can someone please explain how to post pictures right in the thread. Im sure ill be posting a few
Old Nov 18, 2010 | 07:11 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
There's a picture icon when you go to post a reply, you can use that and post a link to a picture hosted somewhere on the web, or use [img] pictureadress [/img] with no spaces
Old Nov 20, 2010 | 05:26 PM
ma777's Avatar
The harmonic balancer was worn out and i bought a new one put it on. I was hoping the car would start up but nothing is ever easy. The timing belt is ruined too. It doesnt sound like it normally does when cranking. Looks like I have a big job ahead of me. I guess ill try a new timing belt first. If internals are messed up, ill be getting an h22.
Old Nov 21, 2010 | 10:27 PM
ma777's Avatar
The timing belts are all on and look good. I really have no idea what to look for. Im pretty sure my internals are messed up. I need to wait for my friend to get back to look at it. I would take it to a mechanic but i dont wana spend money just to have him tell me its unrepairable.
Old Nov 22, 2010 | 12:21 PM
DaInFaMMuS1's Avatar
have a leakdown and compression test done, that can help you asses if it's damaged and where the majority of the damage is without completely ripping it apart.
Old Nov 22, 2010 | 11:14 PM
ma777's Avatar
Got it running today! I had to write and english paper so I didn't get it driving today. My timing was messed up. I just followed a guide for replacing the belts. After all the frustration and worry I'm kind of glad it happened. I went from not knowing what anything was called and not knowing what the hell im looking at to pretty much understanding everything. I just hope everything goes smoothly tommarow.(knock on my wood table)
Still do a compression test right?
Old Nov 23, 2010 | 12:55 AM
P0401's Avatar
I would still do one to make sure you have no bent valves or anything
Old Nov 23, 2010 | 10:08 PM
ma777's Avatar
I drove it around the block with no problems. I didn't want to drive it to much because i had no way of tighting the bolt in the crank tight enough. I need that tool to hold it down while i tighten it. Ill get some real driving in tommarow.
Old Nov 24, 2010 | 07:09 PM
ma777's Avatar
185 psi for all 4 on the compression test. Is there a specific number it should be at. I know its good If they are all very close to each other.
Old Nov 25, 2010 | 10:20 PM
medium1's Avatar
This is what you need Powerbuilt 648796 Honda Crankcase Pulley Removal Tool about $25. How did you get it off in the first place?
Old Nov 28, 2010 | 02:16 AM
ma777's Avatar
it came off on its own..... thats where my problems started
Old Nov 29, 2010 | 09:07 PM
ma777's Avatar
Drove it 75 miles and with no problems! My car never went over 5k rpms. But now when i hit 5k, The gas pedal vibrates..alot
Nizmosis
Oct 13, 2015 02:25 PM
polish_pat
Sep 30, 2015 12:22 PM
juanrl
Sep 29, 2015 03:25 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
njresendez
3G TL Photograph Gallery
Sep 21, 2015 06:32 PM
