The CL broke down
The CL broke down
Car started making a knocking sound under the black cover on the right side of the engine. I assume its the timing belt. I guess it tore. Power steering then went out. I wasnt to far from home so i tryed driving it home. I was driving home put it in nuetral and noticed my rpms were at zero. I guess it finally broke then. I parked it in the middle of the street. Had some old lady help me best as she could. I pushed it up a hill while its raining on me. Im slidin all over. What a shit day.
I guess i just need to buy new belts and hope i didnt mess anything else up while driving it home.
this happened to my DSM a while ago...had to put on a whole new head bc nearly all the intake and exhaust valves were f'ed. hope this isnt the case w u...keep us posted
I hope my engine isnt F'ed either. But if it is h22 is gunna go in it. My dad will have to be on board now if my engine is completely screwed. Ill have it home tonight and know more then.
There's a picture icon when you go to post a reply, you can use that and post a link to a picture hosted somewhere on the web, or use [img] pictureadress [/img] with no spaces
The harmonic balancer was worn out and i bought a new one put it on. I was hoping the car would start up but nothing is ever easy. The timing belt is ruined too. It doesnt sound like it normally does when cranking. Looks like I have a big job ahead of me. I guess ill try a new timing belt first. If internals are messed up, ill be getting an h22.
The timing belts are all on and look good. I really have no idea what to look for. Im pretty sure my internals are messed up. I need to wait for my friend to get back to look at it. I would take it to a mechanic but i dont wana spend money just to have him tell me its unrepairable.
Got it running today! I had to write and english paper so I didn't get it driving today. My timing was messed up. I just followed a guide for replacing the belts. After all the frustration and worry I'm kind of glad it happened. I went from not knowing what anything was called and not knowing what the hell im looking at to pretty much understanding everything. I just hope everything goes smoothly tommarow.(knock on my wood table)
Still do a compression test right?
I drove it around the block with no problems. I didn't want to drive it to much because i had no way of tighting the bolt in the crank tight enough. I need that tool to hold it down while i tighten it. Ill get some real driving in tommarow.
Nizmosis
Oct 13, 2015 02:25 PM
xsilverhawkx
Sep 28, 2015 06:51 PM
Well I doubt it's the timing belt unless you were seriously late on that bit of maintenance, in which case, a lesson well learned.
thats where my problems started
