check engine light PO138
Old Nov 6, 2008 | 05:51 PM
acurazinefan's Avatar
Red face check engine light PO138
check engine light is on, went to autozone code was PO138, they try to remove/erase the code, after driving several miles CEL went back again. trying chevron w/ techron (fuel system cleaner) for now maybe there's some carbon deposits on the sensor i dont know?? would seafoam works??? any suggestions or remedies before replacing the oxygen sensor???
98 acura cl 2.3 stick with less than 90000
Old Nov 6, 2008 | 10:39 PM
Master Bill Flex's Avatar
P0138 - O2 Circuit High Voltage Bank 1 Sensor 2
If thats the case, its most likely just the aft cat 02 sensor.
i dont think there is a single chemical that can help anything in the exhaust. hows the car running? bad MPG may mean a clogged cat in some cases, which may throw off the code... im not sure, but if there is no difference what-so-ever, it may just be the rear o2 sensor. easy fix too
Old Nov 11, 2008 | 05:19 PM
westwood167's Avatar
4th Gear
Before you do anything, try the following
1. turn on the headlights
2. disconnect the battery and wait 15 minutes(leave the headlights on)
3. reattach the battery and start the engine
I have 99 5sp, the engine light stayed on even after I changed the O2 sensor, and the convertor. I even bought a OBD reader to reset it (worked for 1 day, then it came back on!)
The light has been off since I performed the above procedure 3 weeks ago
Good Luck!
Old Nov 13, 2008 | 11:52 AM
Thumbs up
its all ok now no more check engine light !!!
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
