Check engine light
Old Jan 3, 2006 | 10:57 PM
clayto's Avatar
5th Gear
Check engine light
Im getting a 401 code on the OBDII reader should I replace the EGR valve or could it be another issue with emissions? Just bought the car last week. Know nothing about Acura's. I do know its fast!
Old Jan 4, 2006 | 12:21 PM
wilp99's Avatar
im going to assume you have a 3.0, and theres a recall for up to 100k miles from the dealer to replace the valve which is usually good and clean out the carbon in the intake manifold which is usually the problem..
Old Jan 10, 2006 | 10:49 PM
clayto's Avatar
5th Gear
Emissions warranty
Acura now warranties the emissions . So off to the shop she goes! Thanks for the reply, cause it made me research the problem and hopefully gets fixed for free. Now thats cool.
Old Jan 11, 2006 | 04:43 AM
subbuzz's Avatar
07 tl-s in
Originally Posted by clayto
I do know its fast!
compared to a golf cart you got a 3.0?
Old Jan 12, 2006 | 11:01 PM
clayto's Avatar
5th Gear
yes its a 3.0 just got it out the shop they cleaned the manifold and replaced the egr value and tune it up for free. its my first acura and i love it so far. they say its time to change the timing belt. does anyone have info exactly when to change it? some say at 105,000 and some say its safe to 115,000 i would like to know before i lock up the engine from to many miles.
Old Jan 13, 2006 | 02:15 AM
saiko_cl_duck's Avatar
hey, i just talked to Acura today, and for the 99 cl it's as followed
-8 yrs of 80k, whichever comes first
-Warranty covers any damage that was caused by a clogged EGR port
Old Jan 28, 2006 | 11:01 AM
tship's Avatar
Check Engine Light
Shows to be EGR valve. car is 97 3.0 with 110k. What to do? Warranty? If no,do I replace or clean? How do I determine which one to do?
Old Jan 28, 2006 | 08:41 PM
Stew97CL3.0's Avatar
Call your dealer and give them the vin number and ask them if you are eligable for the emmissions recall fro the egr/egr passage. If not the question becomes, are you able to remove the intake manifold yourself, drill out the passage that is clogged with carbon and replace the egr yourself. If not get a price on the repair from your favorite repair facility.
Old Jan 28, 2006 | 10:57 PM
EddieJP125's Avatar
Marine Gulf War Veteran
well i know that mine is out of that recall so i was wondering what i should do?...how easy is it to clean the throttle body, intake manifold and EGR Valve?...and what should i use to clean once i opened and took apart all this shit...?
Thanks Eddie
Old Jan 29, 2006 | 10:23 AM
Throttle body and intake you can clear with spray cleaner. EGR you have to pull off the intake manifold to remove, and drill out the gunk and clean.
Old Feb 2, 2006 | 12:10 PM
EddieJP125's Avatar
At acura they said that it wouldn't work because you need to drill out the carbon...and actually cleaning the egr valve would not be necessary 'cause thats not what is wrong...its the port...?
Old Feb 2, 2006 | 09:28 PM
That's correct, the only way to clean out the carbon, as I said, is to pull the upper intake and egr and drill out the carbon.
You asked how o clean the throttle body and intake also, that you can do with throttle body spray cleaner.
Old Apr 4, 2013 | 11:57 AM
Mrs Mel's Avatar
I am going to order a catalytic converter and oxygen sensor offline, any recommendations on a good brand for my 05 tl?
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
