Check engine light
Check engine light
Im getting a 401 code on the OBDII reader should I replace the EGR valve or could it be another issue with emissions? Just bought the car last week. Know nothing about Acura's. I do know its fast!
im going to assume you have a 3.0, and theres a recall for up to 100k miles from the dealer to replace the valve which is usually good and clean out the carbon in the intake manifold which is usually the problem..
yes its a 3.0 just got it out the shop they cleaned the manifold and replaced the egr value and tune it up for free. its my first acura and i love it so far. they say its time to change the timing belt. does anyone have info exactly when to change it? some say at 105,000 and some say its safe to 115,000 i would like to know before i lock up the engine from to many miles.
Call your dealer and give them the vin number and ask them if you are eligable for the emmissions recall fro the egr/egr passage. If not the question becomes, are you able to remove the intake manifold yourself, drill out the passage that is clogged with carbon and replace the egr yourself. If not get a price on the repair from your favorite repair facility.
well i know that mine is out of that recall so i was wondering what i should do?...how easy is it to clean the throttle body, intake manifold and EGR Valve?...and what should i use to clean once i opened and took apart all this shit...?
Thanks Eddie
Thanks Eddie
Originally Posted by Stew97CL3.0
Throttle body and intake you can clear with spray cleaner. EGR you have to pull off the intake manifold to remove, and drill out the gunk and clean.
That's correct, the only way to clean out the carbon, as I said, is to pull the upper intake and egr and drill out the carbon.
You asked how o clean the throttle body and intake also, that you can do with throttle body spray cleaner.
HeloDown
09-08-2015 06:51 PM
