A/C Always On?
Old May 5, 2008 | 05:25 PM
Jaysfan5432's Avatar
A/C Always On?
Normally I have my climate control set to auto, and about 75. However when I press the off button I can still feel cold air coming out the vents, but the air isn't blowing quite as hard as it would normally (however it is still noticeable). Also even when I manual operate the climate control and select the a/c to turn off, I still feel cold air coming out the vents. What could the problem be? Also how do you guys general run your climate control, on manual or auto?
Old May 5, 2008 | 05:33 PM
AznX TL's Avatar
where is....
im pretty sure this happens to all cars, its just air coming out the vents while you're moving. it doesnt do it while your car isnt moving does it?
Old May 5, 2008 | 07:34 PM
ZeroCL's Avatar
W WHIP.
yeah, same here. only occurs when going a decent speed it seems if its off. Which is awesome when its warm out with the windows open. Seems that if it was at 90 last time, if its off, it still blows hot air, vice versa when its at 60 or so. hmm..
Old May 5, 2008 | 07:45 PM
BruceLandry's Avatar
Also if the a/c was on it would take a while for the evap coil to equalize so you could be feeling residual cooling.
Old May 6, 2008 | 11:42 AM
Im pretty sure air still comes out while the car is stopped, but i'll check the next time i drive.
Old May 6, 2008 | 12:48 PM
ZeroCL's Avatar
W WHIP.
i think its normal. the noise thats coming from mine definitely is not. I have no idea what it is, it keeps making a whining noise when its on. :-(
Old May 6, 2008 | 02:22 PM
What is making the whining noise the fan or the compressor?
Old May 6, 2008 | 06:55 PM
TexasHonda's Avatar
Watch the compressor and cooling fans. When they turn off, the AC system is off. Blower fan could be running on auto, but on manual you should be able to turn completely off.
good luck
Old May 6, 2008 | 07:28 PM
ZeroCL's Avatar
W WHIP.
No idea. I know its when the ac is on. thats as much as i can tell right now. wheres the compressor at? ill pop the hood and check it out tomorrow.
Biggie_B
May 27, 2025 05:51 PM
jdm_94-07TypeS
Oct 7, 2015 11:14 PM
hashbrown
Sep 29, 2015 12:13 PM
lovic87
Sep 15, 2015 06:07 PM
dlknight
Sep 3, 2015 07:54 PM
