Brake lights wont shut off
Old 08-06-2011 | 10:51 PM
Gigolo's Avatar
1999 Acura CL 2.3
just happened...
car has been fine
just now when getting out of car i noticed that the brake lights wont shut off..even the 3rd brake light..
any ideas?
thanx
Old 08-06-2011 | 11:24 PM
Gigolo's Avatar
1999 Acura CL 2.3
ok...just checked it out carefully..looks to be that little blue plastic part thats suppossed to touch the sensor on the pedal itself..for now i just put a penny in the slot so it would shut off...
so how do i fix it properly??what is the part name i need or is there some other generic fix aside from my penny which ill fall out of place as soon as i touch the brake tomoro
thanx 4 info mates
Old 08-06-2011 | 11:53 PM
swoosh's Avatar
takin care of Business in
so you are not pressing the brakes or the hand brake is not up and the brakes lights are on ?
EDIT: read your post above, is there a way you can snap a pic and post it ?
I think your brake pedal is not coming up all the way....how is the braking ?
Old 08-07-2011 | 12:01 AM
Gigolo's Avatar
1999 Acura CL 2.3
its too dark to take a pic right now but basically on the pedal bar theres a slot where im guessing the bolt or plastic thing goes in and it touches the spot where the button that shuts the brake lights on or off is located..
concept like this pic
http://askville.amazon.com/brake-lig...uestId=7140558
http://www.ehow.com/how_5925816_repl...ke-switch.html
hmmmm
now hoping i can actually get the part at local auro store and if so if i can do it myself..lol
oh yeah..and to be clear its not the switch itself that faulty its the little piece that touches the switch itself..(its the piece on the brake bar)
Old 08-07-2011 | 12:20 AM
swoosh's Avatar
the reason I asked is i remember someone doing this on the tsx side if my memory serves right....
trying searching or seeing if they have a similar thread in the 3G garage:
https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-garage-faq-3g-tl-newbies-553554/
Old 08-07-2011 | 12:49 AM
Gigolo's Avatar
1999 Acura CL 2.3
hmmmmm i might just be able to tape a dime or penny onto the bar...
but still looking for the proper way
Old 08-07-2011 | 06:27 AM
Gigolo's Avatar
1999 Acura CL 2.3
ok..found the proper name for the part i need
"pedal stopper pad"
this is basically my issue
http://honda-tech.com/showthread.php?t=2254546
now gonna try to locate one at a store today..if not ill have to keep using my penny method until i do
Old 08-07-2011 | 12:51 PM
swoosh's Avatar
exactly what the tsx guy did....glad you found it....
post some pix of the broken part....
Old 08-08-2011 | 05:51 PM
saiko_cl_duck's Avatar
try acuraautomotiveparts.org
Old 08-08-2011 | 06:44 PM
Gigolo's Avatar
1999 Acura CL 2.3
http://lulzimg.com/view/b8dc10.jpg
this solved it..nice cheap plastic screw..
oh and this is the broken pieces i found on floor
http://lulzimg.com/view/28e7cc.jpg
Old 08-20-2017 | 03:29 PM
uncommon's Avatar
3rd Gear
Hey thanks for making this post. I had the same problem, but this article helped. I used a dime instead of penny so I spent $0.09 cent more than the other guy LOL.
Old 04-16-2019 | 08:27 AM
kbell21907's Avatar
I had same problem, different fix
I understand this is an old thread, but in case anyone is looking at this, I had the same problem in my 2008 RDX. The switch on my pedal was fine, and even after placing a penny there to give it more pressure, the lights were still on.
Turns out I had a blown fuse! All I had to do was go under the hood into the fuse box, looked at the manual to find the correct fuse #, and replaced it. Finally, those damn lights turned off.
I hope this helps anyone who is experiencing the same frustrations I was.
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
Soul_Deamon
4G TL Problems & Fixes
11-02-2015 04:32 PM
SpraykwoN
ILX
09-23-2015 11:44 AM
Stu2414
08-30-2015 07:30 PM
Quick Reply: Brake lights wont shut off
