97 CL Overheating...any ideas?
Old Aug 8, 2006 | 09:49 AM
PACL97's Avatar
Question 97 CL Overheating...any ideas?
My Acura 2.2 CL overheats when I put the air conditioning on. The weird thing is that it only does this some of the time. I took the Acura to a dealership and they told me that it was one of the fans. I replaced the broken fan and it still overheats! When I flushed the radiator, I noticed that there were paper-like fibers collecting under the radiator cap. I don't know if this is related or not...but the whole thing is completely crazy!! Does anyone have any advice?
Old Aug 8, 2006 | 10:18 AM
fuslove's Avatar
PACL97:
My CL was over heating yesterday but all I had to do was put in more anti-freeze. I did in the past though have to put in a new thermostat myself from strauss for $15 and I have yet to change the water pump and hope I don't have to.
I know I have not been helpful but... what the hell its a forum for info.
Old Aug 8, 2006 | 08:19 PM
TexasHonda's Avatar
Overheating when AC is on suggests cooling fan is not running. Make sure the fans are running all the time when AC is on. A fan can be intermittent.
Other things to check.
1) Thermostat - a good candidate as already suggested.
2) Very dirty condensor and/or radiator. Additional AC heat load pushes system into overheating.
3) Loss of coolant - I've had tiny leaks on several occasions that only became apparent when engine would try to overheat. Check hoses and radiator carefully.
4) Bad head gasket - This can cause coolant to backup in the reservoir and overflow, followed shortly by oveheat on engine.
good luck
Old Aug 9, 2006 | 12:29 PM
PACL97's Avatar
good luck
Thanks so much....I will check it out. I know I just purchsed a new fan but I didn't check if it runs all the time when the AC is on. Hopefully, I will find a solution.
Old Aug 10, 2006 | 11:57 PM
subbuzz's Avatar
07 tl-s in
good luck
pray it's not the headgasket,had the same prob but it was 100+ outside. stat changed/flushed radiator/ added coolant and i was good to go.but yeah def check fans.always check simplest solutions first,your prob may not be as complicated as you think...
Old Sep 8, 2006 | 01:42 PM
Krystle941's Avatar
7th Gear
if you replace the fan you really dont need to replace the whole thing, just the fan mator. It will cause half as much. I replaced my fan motor for $40 and a whole new fan would have been $100. All you get with the whole fan is just a new frame. its not worth it.
08KBP_VA
Oct 22, 2019 01:55 PM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
Gout
Nov 2, 2015 12:22 AM
Houston
Oct 8, 2015 01:27 AM
