1997 Acura CL 2.2 "VTEC" not working
Old Dec 14, 2013 | 07:32 PM
Sathya0911's Avatar
3rd Gear
I can't seem to figure out why my VTEC isn't kicking in, I replaced the Solenoid with a used one from my friend's accord & I cleaned the EGR Valve as well. Any suggestions?
Old Dec 17, 2013 | 02:03 AM
Sathya0911's Avatar
3rd Gear
Does anyone know what could be the problem?
Old Dec 17, 2013 | 11:34 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Check your oil level
Old Dec 26, 2013 | 12:03 AM
Sathya0911's Avatar
3rd Gear
I got an oil change, it still isn't kicking in...
Old Jan 2, 2014 | 06:25 PM
Siik Psychotiik's Avatar
7th Gear
I'd check to see if there is an oil leak around the solenoid. The rubber seals can harden and become to brittle to keep the oil in. I noticed on my buddies civic that the solenoid depends on oil pressure to function properly, so if there's a leak it won't work as well, and you'll notice a loss in power too.
Old Jan 3, 2014 | 05:58 PM
MistyMetallic97's Avatar
Angry VTEC kicking in.
I think my solenoid is leaking. I knew my distributor was leaking but it looks like my solenoid is leaking too. My VTEC doesn't work either.
Old Jul 1, 2014 | 09:06 PM
ModMechanic's Avatar
8th Gear
check your cam actuator solenoids. both should have 7-12 ohlms. (check them cold then again at operating temp) if ohlms are good remove the solenoids and probe them with 12 volts to make sure they are clicking (... redirecting oil flow) do this multiple times as your problem may be intermittent. if all is still good suspect a sticky cam or timing belt issue. sometimes running a quart of trans fluid through the engine rite before an oil change will free up the cams but I didn't tell you that
Old Jul 2, 2014 | 08:40 PM
Showmeyourtints's Avatar
I know there are a few conditions that must be met in order for vtec to engage. Oil pressure needs to be seen at the vtec solenoid. And your speedo/tach need to work as well. Sometimes the screen on the vtec solenoid gets clogged. If all these things are good it should kick in. Maybe the used solenoid is bad? Can you test it on a different vehicle?
mada51589
Jan 9, 2025 04:40 PM
chrisr
Dec 4, 2015 02:17 AM
theinsvnity
Sep 10, 2015 10:22 PM
FC2012RDX
1G RDX (2007-2012)
Sep 4, 2015 02:05 PM
PAK74
Sep 3, 2015 09:02 PM
