changing headlight bulb!!!!
Old Nov 29, 2008 | 11:43 PM
jbucko's Avatar
sorry cant figure it out anyone can help me please need a low beam headlight bulb change and they wont seem to come out.
Old Nov 29, 2008 | 11:46 PM
YL Al's Avatar
ok ,as i remember . take out the harness and twist THE BULB HARD.
then install the new bulb,twist back and connect harness
i remember having issues with the bulbs coming out but practice makes perfect.
and do remove the plastic cover(by spinning the clips) that goes across the front
Old Nov 29, 2008 | 11:47 PM
jbucko's Avatar
i had issues getting that off do i pull the wires from underneath out?
Old Nov 29, 2008 | 11:51 PM
YL Al's Avatar
You need to push a little tab that is on the bulb to seperate it from the wires. you may need flathead screwdriver for the job(as your hands may not reach accordingly). as you push the tab down,grab the screw driver and push out the wire bracket down ,so that it will slide out and seperate from the bulb.
EDIT: you had issues getting what out,the harness or the plastic cover that goes across the front? if the harness then read this post.
Old Nov 30, 2008 | 04:49 AM
mitch14's Avatar
CL in lawnmower status
^ i think he means he's having trouble disconnecting the connector from the bulb, i had the same issue. but just push the tab in and force the connector down, you could use a screwdriver like iraqiyl said, that would work....and btw how to remove the bulbs is in the owner's manual , and obviously thigns don't come off easy on these cars, they're like 10 years old, you just gotta put some force into it
Old Nov 30, 2008 | 09:57 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
push the tab in, and then push down on the wiring harness with your thumbs, it should slide down with some work, then just turn the bulb 45 deg counterclockwise and it'll pop right out
Old Nov 30, 2008 | 10:57 AM
swiftt5389's Avatar
i broke the tab off one of mine accidently. Made things a lot easier haha. And it never slipped off . but no im not suggesting you break it.
Old Nov 30, 2008 | 02:33 PM
Myxomatosis's Avatar
remember DON'T TOUCH THE NEW BULBS, any oily residue such as a finger print on the bulb with blow really quick. Hold it by the connector when installing and try not to touch anything, kinda like that game "operation"
Old Nov 30, 2008 | 02:41 PM
DoubleSh0t's Avatar
If you're still having difficultly, it helps to warm up the plastic connector with a blow dryer if you're in a cold area.
Old Nov 30, 2008 | 04:05 PM
GhettoNinja06's Avatar
Skuuuurrrrrt!
I had trouble removing both parts.. I stuck a skinny flat head screwdriver in the tab and used both hands to pull appart the connecter and used a vise grip to twist and pull the bulbs out of the headlight housing.
Old Nov 30, 2008 | 04:42 PM
(Mid-Atlantic)
Not the best advice to get a light bulb out, shouldn't need that much force
Old Nov 30, 2008 | 05:26 PM
mitch14's Avatar
i just swapped out my stock bulbs for some hid's, you should try them, i installed them myself with only little issues and i'm not that mechanically inclined, i did mount the ballast holders with double sided tape, incase i want to put them somewhere else, it sounds but after i ziptie the wires it will look pretty clean.
well atleast cleaner than my buddy's install which involved one ballast being ziptied and his other one screwed directly into the shock tower in his engine bay, really obviously too
i'll see if i can make some comparison photo's soon of the light output of regular versus HID bulbs
Old Nov 30, 2008 | 05:29 PM
a2ndragoon89's Avatar
joe rocks c2s :D
you can bolt the ballasts on. there's plenty of space to play with. go buy some screws and find those holes to play with
Old Nov 30, 2008 | 05:51 PM
mitch14's Avatar
^ i don't really see the point of bolting them down, cuz the only open space in the engine bay on both sides is to have them mounted flat, and i didnt really want to screw into there cuz i don't know what is underneath, plus with double sided tape it would cut down on the vibrations to the ballasts a little bit, i just don't want a bunch of screw holes in my engine bay.
and the ballast my buddy has screwed in in his engine bay looks way more ghetto than my mounted ballasts, plus mine look symetrical this way, which is the way i like it
Old Nov 30, 2008 | 06:02 PM
(Mid-Atlantic)
in a 2.x engine bay, not much room at all in the 3.0's, trust me
Old Nov 30, 2008 | 06:22 PM
mitch14's Avatar
i don't see any problem mounting them with double sided tape tho, it's not like anything is gonna happen to them if i don't screw them down. and this way if i ever go back to normal bulbs there won't be anything left in the engine bay from the hid's
Old Nov 30, 2008 | 06:25 PM
(Mid-Atlantic)
My driver's side ballast is mounted with 3m double s tape, been there for a while now
Old Nov 30, 2008 | 06:31 PM
mitch14's Avatar
^i got the exact same tape, good to know someone else has it done the same way. now i don't feel like my install is so ghetto
Old Nov 30, 2008 | 07:54 PM
mitch14's Avatar
got a pic of what my hid's look like at night for you
couldn't really find any good comparison photos tho, stupid camera sucks at capturing the light output really well
Old Dec 2, 2008 | 10:10 AM
Lawlergaggzorz's Avatar
I also used a flathead screwdriver to push down on the connector and worked like a charm. Mitch14, where did you buy your HIDs?
Old Dec 2, 2008 | 03:05 PM
mitch14's Avatar
^ www.vvme.com hopefully they work fine, so far so good, but it's how long they're gonna last that i'm worried about, oh well, i think they do come with a warranty, and they have replacement bulbs for the HID kits available too
Old Dec 9, 2008 | 02:27 PM
^^^^ you get many people flashing high beams at you? just wondering how glaring they are. I'd be tempted to do the swap, but I dont want to blind oncoming traffic.
Old Dec 16, 2008 | 12:48 PM
1997 Acura CL 2.2 Premium's Avatar
Those lights are great, I have the same ones. There is a problem with people coming at you, they always think my high beams are on when they are not. The lifetime on theses light suck, I am averaging new low beam bulbs every 6 months and the high beams I have not had to replace yet. I have had them for about a year now, they make a huge difference and I praise them.
Old Dec 16, 2008 | 03:28 PM
mitch14's Avatar
nobody has flashed me yet, but don't use that to judge either, even with my last car with projos some dumb ppl still flashed me, and the cutoff line would be below their windows.
Old Jan 4, 2009 | 04:02 PM
Diesirae's Avatar
OMG! The driver's side is such a pain in the dick! I must have tried 1/2 a dozen times already and still can't get the wires off..
I'm not entirely sure what plastic cover you're talking about either .. Do both bulbs go out when one goes bad?
Old Jan 4, 2009 | 04:28 PM
mitch14's Avatar
if you mean you can't get the connector off of the bulb then that would be the same issue that most ppl are having on here, just read all the posts and use that info, push the tab in and you can use a flathead screwdriver to push down on the connector. i don't know what plastic cover he is reffering to. also if you have more than one bulb go out check the fuses first.
Old Jan 4, 2009 | 04:40 PM
(Mid-Atlantic)
if both are out check the fuse first, the tabs on the wires are a pain but you just have to push down with your thumb and try to wiggle it free, it'll go
Old Jan 5, 2009 | 01:43 AM
ZeroCL's Avatar
W WHIP.
I remember when I sucked at removing those.
Old Jan 5, 2009 | 02:37 PM
Jay Daley's Avatar
What a bunch of whiners! JUST DO IT.
Old Jan 5, 2009 | 04:34 PM
ZeroCL's Avatar
W WHIP.
first post of the career...nice.
Old Jan 16, 2009 | 05:35 PM
Diesirae's Avatar
I got one side off with a problem... as it turns out the other side had a piece of plastic wedged in such a way that prevented it from turning....
Anyway, brand new JDM Black headlamps installed yesterday
Old Jan 16, 2009 | 06:34 PM
(Mid-Atlantic)
Hope you like them, but they're not jdm
Old Jan 21, 2009 | 07:58 PM
TopEyes's Avatar
oh boy i cant wait to get mine
thanks mitch cheap investment
Old Jan 21, 2009 | 09:23 PM
incredulous1's Avatar
i hope you got jdm lightbulbs to go with those jdm headlamps... =)
Old Jan 21, 2009 | 09:50 PM
mitch14's Avatar
^no problem man, hope they work out for you, mine and my buddy's HID's both purchased from vvme are still going strong, and for that price it's a lot better than buying some other halogen bulbs that are gonna burn out pretty soon anyways
Old Feb 2, 2009 | 02:47 PM
sholmz's Avatar
3rd Gear
I removed my headlight bulbs and was to replace them with the HID I purchased. When removing the bulb, I broke all the Ivory looking things the bulbs locks under. I can't fine the replacement online so I'm thinking of holding the bulb in place and putting silicone around it.
As you see, I am needing help here. Thanks.
Old Feb 2, 2009 | 09:03 PM
TopEyes's Avatar
^sorry to hear that do ur best to fix it
i had something similar to what happen 2 u
i just use electrical tape.
first two mods complete
-aem sri
-4300k hid/klight
Old Feb 3, 2009 | 01:21 PM
whatever you do, heed my advice and make sure you dont touch the bulb, since it wont be easy to replace. Black silicone would work, but duct tape it in while it's drying....like 24hrs. I was going to suggest epoxy or something like that, but with silicone, at least you can remove it relatively easier.
btw.....how many AZ members does it take to change a light bulb?
pplcrew
Jan 30, 2021 08:59 AM
acuraST
Sep 17, 2015 02:31 AM
Aleax
Sep 11, 2015 11:31 AM
theinsvnity
Sep 10, 2015 10:22 PM
spiel08
Sep 7, 2015 08:19 PM
