Window Is Broke
Old Dec 31, 2003 | 08:08 PM
azn5ucka86's Avatar
Window Is Broke
okay so i was going to safeway and i close my door, i hear a snap and then all of the sudden the window starts to roll down by itself, goes to about half open. so i try to fix it but end up pushing the glass all the way down, i take it home and try to disassemble it and troublshoot, but a white piece of plastic comes out, it looks like its been snapped off or broken, so now my window doesn't roll up and i don't know where to get this fixed at, anyone know what the problem is? or where i can get it fixed at for a reasonable price? how much ya think it'll cost? i've been having a problem with the driver side window too recently, the autodown would never put the window all the way down, but now the window doesn't even go up....need help asap...thanks guys
Old Jan 1, 2004 | 07:57 AM
azn5ucka86's Avatar
anyone?
Old Jan 1, 2004 | 10:11 AM
CLpower's Avatar
teh Senior Instigator
the cable snapped, this is very common on these cars. Gonna have to get a new motor for the window
Do a search, it's been talked about a lot. I think their is a step to step tutorial
Old Jan 1, 2004 | 11:25 AM
97Acura3.0CL's Avatar
ENGAGE MY VTEC BABY!!!!!!
i have this same problem, i have taken the window apart but my window cable did not snap it just came off and i didnt break the white track piece, i think the cable just came loose but i can seem to figure to get it back on, my window has been off for about a good 2 months now and still cant figure the damn things out, i dont want to buy a new one cause i know this one isnt broken from my knowledge and the knowledge of the local mechanic
if you need some help, hit me up on aol im @ jgiguere17
i can help you guide yourself in a troubleshoot
ill be back in town on the 4th, leave your aol name here and ill hit you up
Old Jan 1, 2004 | 11:58 AM
99Black3.0's Avatar
LivesInACLDownByTheRiver
The window works on a cable and pulley system. The cable did not break, it was the white plastic piece that broke. You need to buy a Window Actuator, NOT the motor. There is a large vertical bar that has "taxi" (for lack of better words) that the window is connected to. When you push the button, the "taxi" moves up and down this bar. The motor makes the cables move and makes the window move. Take off the door panel and the white plastic lining, and move the window to the "down" position. There is a hole in the metal of the door that accesses the bolt on the "Taxi" I think there are two bolts. Hold the window in place (where the bolt lines up with the hole) with some special tape so you can remove both bolts and remove the actuator. There are several bolts holding the actutaor in place, remove all of them and take the actuator out.
You can get a new actuator on ebay for the Accord for about $100. If you dont wont to do the install, shops around here charge about $50 for install.
Good Luck
Old Jan 3, 2004 | 06:18 PM
azn5ucka86's Avatar
alright im headin back to san jose on monday, winter session begins.., but it sounds like the motor still works when i hit the window button. I think my best bet would be to buy a new window actuator and then bring it to a shop to install, think that will solve the problem?
one more thing, my AIM screen name is the same as my a-cl name, azn5ucka86
thanks, i will probably leave my car in sf for this week, i don't trust my apartment garage to leave my window wide open in
Old Jan 3, 2004 | 06:49 PM
baka_t's Avatar
The movement has started
It would lengthen the life of the accuator if you lube the window seal on the inside of the door.
Old Jan 4, 2004 | 09:18 PM
azn5ucka86's Avatar
where do you lube exactly?
Old Jan 5, 2004 | 10:59 AM
wilp99's Avatar
i had to get the one for the acura itself. according to acura vs. honda which i called both they were both different partnumbers. (2door accord vs. cl) i payed 135.00 for mine and got it from acura. easy as hell to replace, and the regulator comes with the motor already attached. or go to a junk yard and try the 2dr accord.
Old Jan 5, 2004 | 11:01 AM
wilp99's Avatar
p.s there is NO way to just replace the regulator w/o the motor.
wilp99's Avatar
good luck
Old Jan 5, 2004 | 03:56 PM
azn5ucka86's Avatar
so basically i need to replace the whole unit, does anyone know the part # for this from that oem automative site? dustbuster by any chance if you've read this thread?
Old Jan 11, 2004 | 01:33 AM
1-cl-2-go's Avatar
A-CL Auto-Tech
the website is www.1aauto.com. they have the window motor and regulator together for $75.00 and ships quick too. go to the website, go to the left hand corner, punch in your make and model, hit power window motors and the part will show up(2.2 and 3.0 use the same part so ignore the year and engine size).
i hope this helped you out i know it sure beats paying $130-$180 for a part if you can get it for half price somewhere else brand new.
Old Jan 11, 2004 | 07:20 AM
dennis's Avatar
Get the shit from 1A Auto. I ordered mine through ebay. I've gone through 2 window regulators (I'm on my third). The cables inside the motor got tangled on both of them. 1A auto offers a lifetime warranty. They've saved my ass twice so far.
le^2
Mar 17, 2026 05:06 AM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
AcuraKidd
Sep 25, 2015 11:18 PM
