Wierd Problem
Wierd Problem
ok so i got my clear signal lenses and i installed them and went to buy yellow bulbs (two on each) and i installed them, then tried them out and worked fine. but right now i thought i would take it out for a cruise so i got in my car and checked all my lights and they were working, then i tried starting the car and the dash lights, radio lights, ac lights, and clock blinked about 4 times and i also heard this clicking with each blink of the lights. if i turn my lights on before starting the car they also blink. wtf is up?
could it be the bulbs or what
dont know if this will help but i noticed that when i put the turn signal the lights inside dim then go back with every blink of the light.
does anyone know what the hell is going on with my car. thanks.
could it be the bulbs or whatdont know if this will help but i noticed that when i put the turn signal the lights inside dim then go back with every blink of the light.
ok so i put the stock lights back in and still same problems i dont know whats going on here
btw did i have to disconnect the battery to replace the bulbs because i didnt and the time changed to 1:00 by itself
having the same problem now...
doesn't seem to be the lights that are my problem though, maybe something with the starter. Only starts to short out once i turn the key completely and then everything goes black and flickers.
Did you replace anything other than the clear lenses and bulbs, ie;bulb harness? If not, probably the batery has a spent cell. If so, check that proper ground has been attained. Some shops will hook up your charging system and test it for free. If you can't get the car there, take the batery and test it.
As for the starter, worste-case-senario. You have spent the starter relay or the solinoid.
Good luck.
Good luck.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
