wierd noise
wierd noise
ever now and then when i turn my fan on for the heat it makes this wierd screeching sound and after awhile it stops has anyone else had this problem? is the motor going or should i just grease it? thanx
The main bearing in your fan motor is toast. Eventually, it will stop working. This happened in my Teg, and it went out like a month later.
Kind of a pain in the ass to do, but the fan is not that expensive. I paid $75 for a new one.
Good luck.
Good luck.
Originally Posted by <syphers>
awesome great news. so greasing it wont help?
Mine was doing the same thing a while back. My thermostat was stuck open which was causing the noise. If your heater is still putting out heat then this is not your problem, but if the heat is weak and you hear a shuddering noise under your glove box then the thermostat is prob. stuck open.
Thats one more thing I love about our cars is the heater is a beast. My Fiance's Civic takes a good 30 minutes to get warm enough to do anything. And even when its at its warmest it is nothing compaired to the heat my car puts out.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by ajtcl
replacement fan for the win....
is it easy? if so may you guide me or help me find a write up? because i been searching and have not found anything. i didnt wanna touch anything till i have read about it first. trying to save up for a manual book the kind the dealer use($75+).
thx
jeez i didnt kno so many people had this poblem i've pulled it before pretty easy just in a bad spot its four bolts and one wire harness. . last time i pulled the fan there were leaves and shit inside.
...... an accord fan would work rite
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
