why so much static?
Originally Posted by Sumaccordguy1994
Its probably the little motors inside working and creating noise, this normally isnt heard but since you have such a strong signal going into another amplifier, any little noise can be heard. If you change tracks you'll probably hear it as well.
You're going to need an adapter to install an aftermarket stereo to the bose stereo.
My JVC has a little bit of hiss when I play a CD. I think it is just the sound interference coming from the unit itself being amplified. Quiet passages, and the dead space between tracks is when I notice it. It does not do it when playing from the XM or the radio. In fact, the hiss I hear has a rythmic quility to it that could be construed as the optical pickup for the CD. In fact, I am sure of it. I never noticed it in my Teg because I didn't have an amp, but in the CL, the amps magnify that signal noise. That is probably your issue as well.
Good luck.
P.s.
If it were a ground issue, you would have problems with the radio as well as the CD.
i think if it is the ground problem the power would go in and out, hu would dim and undim. try pulling ur HU out and wrap a thick layer of electrical tape around the the yellow wired. could be a EMI issue.
4drviper
Apr 23, 2025 07:13 PM
