Why bom bom bom sound come from muffler
Old Nov 11, 2004 | 11:22 AM
aRIff's Avatar
Ottoman Empire
There is still something wrong with my car and until monday I try to find out myself, otherwise I will take the car to dealer.
between 1500-2500prm I heard this sound from the muffler;
"bom bom bom bom"
I already have "Cylinder 2 missfire error"
Injectors are fine, fuel filter is fine
Need some ideas what it could be... thanks guys...
Old Nov 11, 2004 | 11:29 AM
Hobo's Avatar
Flap.
plugs
Old Nov 11, 2004 | 11:53 AM
Ron Burgundy's Avatar
Just the facts...
Originally Posted by Hobo
plugs
and wires?
Old Nov 11, 2004 | 12:19 PM
xxx's Avatar
xxx
"Baby come around here let me see that sexy body go BOM BOM BOM..." quote by P. Diddy.
aRIff's Avatar
Ottoman Empire
is there any easy way to check the wires works fine or not ?
Old Nov 11, 2004 | 01:20 PM
Hobo's Avatar
Flap.
just visually inspect for nay damage, and pull the plugs and test for spark and make sure they are not fouled.
Old Nov 11, 2004 | 10:13 PM
sumdumguy's Avatar
a jawful a somethin awful
my girls civic started going bom bom bom
and I thought it was something serious, cuz the car started stuttering too. I checked the wires to see and they looked fine. put in fuel system cleaner. worked then started again even worse. I took it in for a diagnostic test. and $107 dollars later, I find out the plugs were over gapped. took two seconds to fix. the diagnostics test came up with two misfiring cylinders too. the car runs like a dream now.
Old Nov 11, 2004 | 10:32 PM
Hobo's Avatar
Flap.
plug problems can be bad, but are easy fixes
Old Nov 11, 2004 | 11:13 PM
wilp99's Avatar
or an exhaust leak. the boom boom boom noise from an exhaust leak is from the engine sucking air back into the exhaust thru ght hole. doubt it tho. check for the plugs. get some elcheapo's and find out.
Old Nov 12, 2004 | 12:26 AM
WolfBoy's Avatar
Flamenco Blk 3.0CL PREM
u mean backfire ??!!
Old Nov 12, 2004 | 12:42 AM
shineynitelite's Avatar
NAWWWWSSSSSS
lol SUMDUMGUY.. CSK along with more stores have free AUTO XRAY UNITS..
Old Nov 12, 2004 | 09:29 AM
wilp99's Avatar
not really more like lack of back pressure. same thing happens when uve got too big of exhaust on ur car. its really bad for the valves. and could burn them out.
but like i said get some $1.00 spark plugs and see what happens.
Old Nov 12, 2004 | 10:38 PM
sumdumguy's Avatar
well they wern't gonna say that when I go in askin for a diagnostic
Old Nov 14, 2004 | 12:12 PM
aRIff's Avatar
Ottoman Empire
I just installed new spark plugs.. car a little smooter but the problem is still there..
Old Nov 14, 2004 | 03:46 PM
wilp99's Avatar
check ur distributor cap and make sure it is totally tight... all 3 screws. infact take it off and make sure the rotor is still good.
Old Nov 14, 2004 | 04:40 PM
aRIff's Avatar
Ottoman Empire
new cap, new rotor. tight... still doing same thing...
Old Nov 14, 2004 | 05:15 PM
sumdumguy's Avatar
have you ever had your fuel system flushed? could be clogging injectors
Old Nov 14, 2004 | 05:56 PM
wilp99's Avatar
check ur plug wires. well the ends where they connect to the plugs. make sure all the clips are inside and they are tight and snap when they are installed. also check for spark leak. itll be on the plastic posts that go inside ur engine and will be bout the size of a "." and it will cause this problem. u just might to change them just to rule this problem out.(hate to see u go to acura and they do all these things first and u still have to pay for them even if they do not work) have u tried the injector light pin yet?
Old Nov 14, 2004 | 07:29 PM
aRIff's Avatar
Ottoman Empire
yes I did about a month ago. nothing changed
DerrickW
Nov 15, 2015 05:52 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
merc009
Sep 29, 2015 03:06 PM
hashbrown
Sep 29, 2015 12:13 PM
Rcelestino93
Sep 23, 2015 10:01 PM
