Whining noise
Old Sep 7, 2004 | 09:50 PM
some1's Avatar
You know him right?
Whining noise
I'm getting a whining-like noise. I can hear it the most when the car isn't moving. I can hear the whine when its idling, and as I accelerate, the whining gets louder and louder to an extent. I do not have an aftermarket intake, but I have added a "custom" ram air tube that runs from the stock air intake to the front of the car. I have had this on for 3 years and had no problems. The noise only started a few weeks ago. Any ideas???
thanks
Old Sep 7, 2004 | 09:55 PM
CleanCL's Avatar
i kind of hear the same thing, i notice a "whirring" sound at around 60mph+ i can't figure out what it is
p.s. i have a 01 cl
Old Sep 7, 2004 | 10:27 PM
Motohip's Avatar
I'm a llama :(
Turn off the stereo and see if it dissapears. Sometimes it can cause interference. Also check to see if you have any exhaust leaks or holes. Hope that helps.
Old Sep 8, 2004 | 08:18 AM
wilp99's Avatar
my pcv valve wines at idle. there was a recall on this. for rerouting the hose. what i did to find it was move the pcv valve at the top while it was running and if it changes pitch then that is ur problem.
Old Sep 8, 2004 | 01:04 PM
babyloc86's Avatar
i also think itz the engine noise from the speakers cuz of ur system wiring.
Old Sep 8, 2004 | 02:53 PM
some1's Avatar
You know him right?
I shut off the stereo and the noise was still there. I'm pretty sure its not stereo related. I still have to look into that pcv valve. The only problem with this is that the noise is best heard from inside the car. I've opened the hood and listened close to the engine and its hard to hear. I've also shut off the ventilation (air/heat) to see if its the fan making the noise, but this is not the case.
Old Sep 8, 2004 | 04:15 PM
Stapler's Avatar
have you had any work done to it lately,
Old Sep 8, 2004 | 09:36 PM
some1's Avatar
You know him right?
I did have some work done on it, but the reason why I didn't say anything was because the whining noise started a couple of weeks before I had the work done. I put a waterpump, timing belt, a few other belts, distributor cap, wires... It does sound like something to do with the belts/fan just because of how the sound increases when I accelerate.
Old Sep 8, 2004 | 11:45 PM
circuitcah's Avatar
Could it be the tranny or other drivetrain parts? Just a thought.....
Old Sep 9, 2004 | 12:18 AM
DanMan1464's Avatar
Autobot
i mguessing tranny
cuz when i installed my short shifter into my IS300, the transmission whining can be heard when accelerating.
I'm not saying that you have a short shifter or something, but that maybe the sound dampening thing module piece of thing might be malfunctioning or something.
Old Sep 9, 2004 | 12:07 PM
juicep60's Avatar
your noise
Hey I have a 97 3.0 cl and the whirring noise you are hearing may be that your alternator is going bad. Mine just went out the other day after I too noticed that this whirring noise was getteing worse and worse. You might want to get that checked untill you break down.
~Juice, Good luck
Old Sep 9, 2004 | 04:58 PM
Motohip's Avatar
I'm a llama :(
~Juice, Good luck
Yeah, I forgot about that one. Happened to me too!
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
