What transmission Fluid are you using?
Old Nov 9, 2009 | 09:37 PM
Mach30SiR's Avatar
Bagel Bomber
What transmission fluid are you using, and what sized engine? (Automatic)
I tried asking in the Problem & Fixes sub-board, but no responses
https://acurazine.com/forums/1g-cl-problems-fixes-71/tranny-fluid-745905/
Thanks!
Old Nov 10, 2009 | 07:23 AM
Mach30SiR's Avatar
Bagel Bomber
Did this get moved?
Old Nov 10, 2009 | 03:51 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
I use Honda ATF, and only Honda ATF
Old Nov 10, 2009 | 05:49 PM
Myxomatosis's Avatar
X2 but bring your wallet, just a warning
Old Nov 10, 2009 | 08:12 PM
Mach30SiR's Avatar
Bagel Bomber
Both Mobil 1, amsoil and Valvaline say they are ok to used in Honda transmissions. At 10 bucks a quart, and needing ten quarts to properly drain and fill three times, thats tooo much.
I was afraid I would get this answer
BTW thanks for moving the thread chris
Old Nov 10, 2009 | 11:21 PM
Shadoh's Avatar
What does our manual trannies need? Honda MTF?
Old Nov 11, 2009 | 04:50 AM
asianspec's Avatar
no we can use Honda ATF also. plus there is no such thing as MTF
Old Nov 11, 2009 | 08:15 AM
(Mid-Atlantic)
a lot of people on here use the GM Syncromesh
Old Nov 11, 2009 | 12:55 PM
Shadoh's Avatar
Was worth a shot :p
So ATF or GM syncromesh mk ty
Old Nov 11, 2009 | 03:18 PM
Mach30SiR's Avatar
Bagel Bomber
Is anyone using Mobil 1 or Valvoline ATF?
Old Nov 11, 2009 | 05:18 PM
GhettoNinja06's Avatar
Skuuuurrrrrt!
I'd get GM Syncromesh. Honda tranny shit isn't really know for reliability...
Old Nov 11, 2009 | 06:28 PM
Blazin Si's Avatar
Pennzoil Synchromesh
GM Synchromesh is over twice the price and is exactly the same stuff.
Old Nov 11, 2009 | 07:43 PM
SupraManAG's Avatar
One custom CL
10W30 for my manual. Works like a charm
Old Nov 11, 2009 | 09:55 PM
teh CL's Avatar
that's what i use..
Old Nov 14, 2009 | 11:39 AM
Nakamichi's Avatar
~[ô¿ô]~
Amsoil Synthetic Universal Automatic Transmission Fluid on 3.0
Old Nov 14, 2009 | 05:46 PM
Mach30SiR's Avatar
Bagel Bomber
Thanks - I was hoping you would chime in. I haven't seen you posting in a while. Where do you get your Amsoil in NoVA? Thoughts on Mobil 1 synthetic or Castrol Synthetic that say they can be used in Honda's?
Old Nov 15, 2009 | 10:15 PM
Nakamichi's Avatar
~[ô¿ô]~
I've been visiting the bimmer forums recently, trying to purchase the current M3. Not sure if I want to join the "can only buy the $20 BMW engine oil from dealer" club on that oil burning vehicle. Really wish Acura/Honda made an equivalent performance car.
I buy my fluid at Amsoil's website. Amsoil's discount for "preferred accounts" fairly generous and the account is free. Shipping is around $13. Since I usually buy engine and tranny fluid at the same time for both of my cars; it offsets the tax of local dealers.
I have only used Z1 and Amsoil ATF, but there are countless other folks who have used those (M1 ATF and Castrol Import ATF) on trannies on oil forums. I have yet to hear anything negative. Are you willing to be the guinea pig ...err... pioneer for the 1G CLs?
Old Nov 16, 2009 | 07:29 PM
Jim Truett's Avatar
Um, Really?
Don't use the ATF in a manual trans. There are better alternatives.
I use Valvoline Maxlife in my '99 3.0. Works great and has a 65 degree higher flashpoint than Honda ATF-Z1 as well as a synthetic base stock for only $4 a quart.
Old Nov 16, 2009 | 09:10 PM
asianspec's Avatar
well thats a first.
Old Nov 18, 2009 | 12:49 PM
Mach30SiR's Avatar
Bagel Bomber
Not yet - But the longer I weight, I might. I'm thinking about leaving it alone, dont fix whats not broken, even though the fluid is filthy.
Old Nov 18, 2009 | 01:55 PM
(Mid-Atlantic)
well thats a first.
No, they've been sellin that shit for years
Old Nov 18, 2009 | 04:12 PM
asianspec's Avatar
i ment for me.
Old Nov 18, 2009 | 04:43 PM
Cocoa's Avatar
2600lb CL
I only used Redline ATF in my 3.0, the shifts were quicker, and smoother compared to cheaper ATF.
I would use cheap ATF to flush out my tranny, which consisted of having to drive it around for X miles as well to criculate the fluid that was in the torque convertor. So by doing so, you will feel the difference between the cheap ATF, and the better ATF in the end.
Johnathon, manual transmissions use gear oil, so when people ask for fluid in their manual transmissions, gear oil is the most common terminology used. But every once in awhile you'll come across a product that simply calls it, MTF.
Old Nov 18, 2009 | 04:46 PM
Cocoa's Avatar
2600lb CL
If you haven't been changing the ATF regularly already when it's supposed to be changed, then you might come across issues soon after changing it. Sometimes that filthy fluid is what's holding the clutch packs together. So it wouldn't be surprising to notice your tranny slip after flushing out the bad fluid. Just wanted to throw that out there.
Old Nov 18, 2009 | 09:44 PM
asianspec's Avatar
hmmm. something new i just learned today. btw. hit me up on my cell. lol
SidhuSaaB
May 30, 2020 12:40 AM
steve
Sep 30, 2015 09:23 PM
hpfiend
Sep 27, 2015 06:59 AM
mellsonnj
Sep 24, 2015 04:42 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
