What transmission fluid are you using, and what sized engine? (Automatic)
I tried asking in the Problem & Fixes sub-board, but no responses
https://acurazine.com/forums/1g-cl-problems-fixes-71/tranny-fluid-745905/
Thanks!
Thanks!
97BlackAckCL
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
close
- Join DateJan 2005
- LocationShitsBurgh
- Age44
iTrader Positive Feedback100
iTrader Feedback Score(6)
Liked:4,669 Times in 3,213 Posts
I use Honda ATF, and only Honda ATF
Myxomatosis
close
- Join DateJul 2008
- LocationPK NY
- Age45
iTrader Positive Feedback0
iTrader Feedback Score(0)
Liked:42 Times in 32 Posts
Quote:
X2 but bring your wallet, just a warningOriginally Posted by 97BlackAckCL
Both Mobil 1, amsoil and Valvaline say they are ok to used in Honda transmissions. At 10 bucks a quart, and needing ten quarts to properly drain and fill three times, thats tooo much.
I was afraid I would get this answer
BTW thanks for moving the thread chris
asianspec
close
- Join DateJan 2006
- LocationPhotography Forum.
iTrader Feedback Score(1)
Liked:1,100 Times in 833 Posts
Quote:
no we can use Honda ATF also. plus there is no such thing as MTFOriginally Posted by Shadoh
What does our manual trannies need? Honda MTF?
97BlackAckCL
(Mid-Atlantic)
(Mid-Atlantic)
close
- Join DateJan 2005
- Age44
Quote:
a lot of people on here use the GM SyncromeshOriginally Posted by Shadoh
Quote:
Was worth a shot :p
So ATF or GM syncromesh mk ty
Skuuuurrrrrt!
I'd get GM Syncromesh. Honda tranny shit isn't really know for reliability...
Pennzoil Synchromesh
GM Synchromesh is over twice the price and is exactly the same stuff.
teh CL
close
- Join DateDec 2004
- LocationKelowna
- Age38
Liked:999 Times in 650 Posts
Quote:
that's what i use..Originally Posted by 97BlackAckCL
Quote:
Thanks - I was hoping you would chime in. I haven't seen you posting in a while. Where do you get your Amsoil in NoVA? Thoughts on Mobil 1 synthetic or Castrol Synthetic that say they can be used in Honda's?Originally Posted by Nakamichi
Amsoil Synthetic Universal Automatic Transmission Fluid on 3.0
~[ô¿ô]~
Quote:
I've been visiting the bimmer forums recently, trying to purchase the current M3. Not sure if I want to join the "can only buy the $20 BMW engine oil from dealer" club on that oil burning vehicle. Really wish Acura/Honda made an equivalent performance car. Originally Posted by Mach30SiR
I buy my fluid at Amsoil's website. Amsoil's discount for "preferred accounts" fairly generous and the account is free. Shipping is around $13. Since I usually buy engine and tranny fluid at the same time for both of my cars; it offsets the tax of local dealers.
Quote:
I have only used Z1 and Amsoil ATF, but there are countless other folks who have used those (M1 ATF and Castrol Import ATF) on trannies on oil forums. I have yet to hear anything negative. Are you willing to be the guinea pig ...err... pioneer for the 1G CLs? Originally Posted by Mach30SiR
Quote:
Um, Really? Originally Posted by asianspec
Don't use the ATF in a manual trans. There are better alternatives.
I use Valvoline Maxlife in my '99 3.0. Works great and has a 65 degree higher flashpoint than Honda ATF-Z1 as well as a synthetic base stock for only $4 a quart.
Not yet - But the longer I weight, I might. I'm thinking about leaving it alone, dont fix whats not broken, even though the fluid is filthy.
97BlackAckCL
(Mid-Atlantic)
(Mid-Atlantic)
close
- Join DateJan 2005
- Age44
well thats a first.
No, they've been sellin that shit for yearsasianspec
close
- Join DateJan 2006
i ment for me. Originally Posted by 97BlackAckCL
2600lb CL
I only used Redline ATF in my 3.0, the shifts were quicker, and smoother compared to cheaper ATF.
I would use cheap ATF to flush out my tranny, which consisted of having to drive it around for X miles as well to criculate the fluid that was in the torque convertor. So by doing so, you will feel the difference between the cheap ATF, and the better ATF in the end.
Johnathon, manual transmissions use gear oil, so when people ask for fluid in their manual transmissions, gear oil is the most common terminology used. But every once in awhile you'll come across a product that simply calls it, MTF.
2600lb CL
Quote:
If you haven't been changing the ATF regularly already when it's supposed to be changed, then you might come across issues soon after changing it. Sometimes that filthy fluid is what's holding the clutch packs together. So it wouldn't be surprising to notice your tranny slip after flushing out the bad fluid. Just wanted to throw that out there.Originally Posted by Mach30SiR
asianspec
close
- Join DateJan 2006
hmmm. something new i just learned today. btw. hit me up on my cell. lolOriginally Posted by Cocoa
I only used Redline ATF in my 3.0, the shifts were quicker, and smoother compared to cheaper ATF. I would use cheap ATF to flush out my tranny, which consisted of having to drive it around for X miles as well to criculate the fluid that was in the torque convertor. So by doing so, you will feel the difference between the cheap ATF, and the better ATF in the end.
