What are the codes???
Old Jan 29, 2002 | 06:09 PM
TwEeDeR's Avatar
My check engine light turned on tha otha day, and i heard dat you can touch some wire and the check engine light will blink a certain number of times and dat number of times means wutz wrong wit it, but you gotta have some special book to see tha code, do any of u kno them???
Old Jan 29, 2002 | 06:26 PM
niedejb's Avatar
Swaps? $3000 for 50HP? :(
Im working on it give me an hour
Old Jan 29, 2002 | 06:45 PM
SumkidwithaCL's Avatar
Turn Signals are good!
you need a code reader that plugs into the car, that comes with the book of codes. You can get them from JC Whitney. Its most likely a bad oxygen sensor or the egr valve... if your car is under warranty bring it to the dealer.
Old Jan 29, 2002 | 06:57 PM
niedejb's Avatar
I've posted all the codes on the "resources" portion of my web page.
Feel free to PM or email with any more questions.
You have to look for the connector. Took me a while to find it.
niedejb's Avatar
You can send me the money you would have spent on the code scanner
Old Jan 29, 2002 | 08:19 PM
Is it the connector behind the ash tray?? Or is there a different one that you can just "hot wire" behind the dash or something? Im wondering about this too for future reference when my warranty runs out.
Old Jan 29, 2002 | 08:28 PM
niedejb's Avatar
I dont know where your ashtray is but.....
Old Jan 29, 2002 | 10:05 PM
dcsquirm88's Avatar
Yup thats the obdII connector thing. I did it tonight to Tweeder's car it took a second once i found a paper clip. You just connect both ends of the paper clip into both holes on the blue connector. Then you turn you key to 3 position. Your check engine light will start flashing. Long flashes count as 10's and short flashes count as 1's. Example 6 long flashes and 5 short flashes=65 Then the pattern will repeat itself.
Which was the code for tweeders car by the way. So forget about buying an obdII scanner.
niedejb thanks for posting up the codes, mad props
Old Jan 30, 2002 | 12:11 PM
TwEeDeR's Avatar
aight thankz niedejb for tha codes, Yea me and dcsquirm88 were looking at it yesterday and it wuz tha 0-2 sensor...
Old Jan 30, 2002 | 02:13 PM
niedejb's Avatar
I know how to disable those too. As long as its the 2nd sensor you dont need it. :P
Old Jan 30, 2002 | 03:44 PM
TwEeDeR's Avatar
what would disabling the 2nd sensor do???
Old Jan 30, 2002 | 04:48 PM
niedejb's Avatar
2 things
1: Save you the cost of a new one if the ECU's throwing the check engine light. $150.
2: Allow you to use a "racing" cat (straight pipe). Cheaper than legal ones and more HP.
Old Jan 30, 2002 | 10:50 PM
dcsquirm88's Avatar
niedejb this is the website your talking about right?
http://www.syrupcity.net/~niedejb/o2.html
For some reason after I installed my racing cat my check engine light didn't go off and still hasnt gone off. My secondary o2 sensor is just pretty much tucked underneath my car. Since the racing cat didn't come with hole for it. Guess I didn't have to do a mil eliminator.
Old Jan 31, 2002 | 11:28 AM
exxxciteCL's Avatar
That's not the OBD II connector. The OBD II connector is behind the ashtray (just yank it out and it's right there). The connector under the glove box that you short out with a paperclip is just something honda puts on their cars.
In order to use the ODB II connector in the ashtray you need a cable and the neccessary software. They sell them for palm pilots and laptops and such... here is a link with some pics:
http://www.obd2.com/
Old Jan 31, 2002 | 11:55 AM
keuka1's Avatar
exxxciteCL you realize it is cheaper to "PAY" the dealer to fix the problem then buy the software and palm pilot to diagnois the probelm.
Keuka1
Old Jan 31, 2002 | 12:02 PM
exxxciteCL's Avatar
Keuka1
I'm not suggesting buying one or anything, I'm just trying to point out the differences between the two connectors. Even if I did buy it, I wouldn't trust myself to properly interpret whatever the OBD II system spits out at me.
Jamus22
Jun 11, 2023 10:08 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
mars
Sep 28, 2015 11:03 AM
