What all is involved in replacing a head?
Shop offered to put my old head on my "new" POS motor (bent valve = 90% compression loss in cylinder 1) with a new head gasket for $350
I don't have $350 and I think I can do it myself, I'm just not sure I'm clear on what all is involved. I think it's:
unbolt exhaust mani & drop
detach fuel supply, intake & all wiring from IM
pull timing belt cover, loosen tensioners, pull timing belt off @ drivers' side direction
pull head
old motor (out of car)
pull head
straightedge head & see if it needs machining (overheated once)
if not, install new $150 head gasket & reinstall
my worry is that I'm oversimplifying the timing belt part, so I'm looking for a walkthrough or a manual section or an FAQ etc ...
thanks guys
MY CAR WILL RUN AGAIN!!
so i can sell it
pull head
pull head
thanks guys
so i can sell it
If your having to come on here and ask chances are you need to let a qualified repair shop do it. you'd hate to have two junk f22 motors. If you do decide to do it make sure to get the repair manual so that you know the torque specs and torque order.
pull head
pull head
thanks guys
so i can sell it
pull head
pull head
thanks guys
so i can sell it
cycdaniel
12-17-2019 10:58 AM
