Weird Issues, Episode 3 (Getting better but not quite there)
Ok, so ive fixed every single problem in my list except one!
My brake lights still dont light up. I checked the "stop light" fuse thats 20a under the hood and it is fine, i replaced it just to be sure, and they still dont work.
From what i can tell from teh Haynes wiring diagram....the only thing between the taillamps and the fuse is the pedal switch, but they dont work even when i fiddle with it on my own, with my finger and stuff.
Is there any other fuse/relay or anything that I can check to see why this happened?
Also, all 3 brake lamps stopped working all at once, it is somehow possible they just all 3 blew up at one time?
wow, have you checked all the connections, and have you checked the wiring, cause i highly doubt all 3 went out at the same time. also, check any relays.....just a thought
Originally Posted by saiko_cl_duck
wow, have you checked all the connections, and have you checked the wiring, cause i highly doubt all 3 went out at the same time. also, check any relays.....just a thought ![2 Cents](https://acurazine.com/forums/images/smilies/2cents.gif)
They are simply 3 lamps, to the switch, to the fuse. Thats it.
So im not sure where its messing up.
My only thought right now, is that a surge or something happened and blew the lamps but not the fuse? Dunno.
Infact, ill go out there right now and see if the filaments are busted.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Did you check to see if the bulb is burned out in the 3rd brake light, or do u have a wing?
Ok...
I went out there, the third brake light (not on the spoiler) wont light up no matter what. I took the two side brake lights out and sat them insid the trunk, and looked through the backseat hole as i pushed hte pedal....it seems they worked most of the time, but would cut off every few pedal pushes.
I got a 14mm wrench and tightened the pedal swithc down as far as it could go, and it took care of the lights just quitting after a few pushes, so i think i have it solved. However, my third brake light (not spoiler) doesnt ever light up when i push the pedal and it doesnt look burnt out because the filaments are fine, and there is no scorching.
Yes i do have a spoiler.
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
(Mid-Atlantic)
(Mid-Atlantic)
![Doh](https://acurazine.com/forums/images/smilies/doh.gif)
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
oh ok. That makes sense.
Why was Acura numbnuts enough to keep the third brake light on there if they were gonna put LED bar on the spoiler?
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
(Mid-Atlantic)
(Mid-Atlantic)
Why was Acura numbnuts enough to keep the third brake light on there if they were gonna put LED bar on the spoiler?![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
![Soopa](https://acurazine.com/forums/images/smilies/soopa.gif)
Thus concludes the weird issues trilogy ![Soopa](https://acurazine.com/forums/images/smilies/soopa.gif)
It was never just the third light out, it was all of them.
But tightening the switch seems to have had a positive effect. So i'll see how that works out over the next few days.
(Mid-Atlantic)
(Mid-Atlantic)
But tightening the switch seems to have had a positive effect. So i'll see how that works out over the next few days.![Tomato](https://acurazine.com/forums/images/smilies/tomato.gif)
snorf
11-04-2019 06:44 AM
