U-Joint
Old Mar 6, 2003 | 11:06 AM
PRmade's Avatar
U-Joint
CL 2.3 '99. I feel and hear a clunking noise everytime I release the clutch at low speeds on traffic. Anybody else had this problem? I'm kinda sure is a worn-out driveshaft u-joint...Am I right or not? Seeking advise!!!!
Old Mar 6, 2003 | 11:48 AM
Kiljaedoen's Avatar
Im not sure if our car has a drive shaft.
I know the clunking your describe is something to worry about in a rear wheel drive car.
not sure about ours thou ???
Old Mar 6, 2003 | 11:56 AM
97CL2.2's Avatar
I'm just another person that doesn't know...
Motor mounts?? got me~
Old Mar 6, 2003 | 12:50 PM
CLpower's Avatar
teh Senior Instigator
does it do it when you go in reverse sometiems? Or up into a driveway? Is it a loud clunk?
Old Mar 6, 2003 | 01:05 PM
ryder2.2's Avatar
give me your H22!
Yeah i have the same problem in cold weather. I think it is either the CV joints are going or the lower ball joints on the control arms. Its only when putting a small amount of torque in first and second gear. It could also possibly be the sway bar bushings clunking i was thinking.
Old Mar 6, 2003 | 01:13 PM
AtlCl's Avatar
Not AtlCl98 or Atl-CL
I had this problem and it turned out to be loose bolts on the front crossbar that holds the front motor mount on it. There were 3 bolts loose on each side where it connects to the frame. The torque and jerking the car caused the engine to move back and forth and slam on the tranny.
chaiwala
4G TL Problems & Fixes
77
Mar 30, 2015 10:34 AM
Jstew
Oct 17, 2014 06:30 PM
DPMoney
Oct 14, 2013 07:21 AM
lsg2776
1G TL (1996-1998)
Sep 21, 2008 07:59 PM
