Transmission shifting
Old Apr 17, 2002 | 07:12 PM
Ricka220's Avatar
Not Fast But Built 2 Last
With my 97 3.0 CL, the trans always seems to be in a higher gear than it should be. The car will downshift to a lower gear, but then of course there is a lag in doing that. Is there some sort of adjustment for this, or some type of mod? I have only had this car for about 4 months, does anyone else find this to be the case with theirs?
Thanks,
Rick
Old Apr 17, 2002 | 11:07 PM
Ricka220's Avatar
Well then.....
1)Either nobody has ever thought this to be a problem.
2)Mine is a rare case.
3)Or everyone is just used to it and I'm getting anal over the way my car shifts.
Old Apr 17, 2002 | 11:22 PM
TampaCL's Avatar
I've been looking at this trying to figure out what you mean. I've never had a problem with my tranny being in a higher gear. Does this happen for you under hard acceleration only or all the time?
Old Apr 17, 2002 | 11:25 PM
Zerostatic's Avatar
100% Dominicano
I got the same problem, so it's not just your car. Maybe it was a bug in the 97 cars. It's not that bad, but I feel the same way you do.
Old Apr 18, 2002 | 12:55 PM
cvthug's Avatar
I know exactly what your saying.....I got that problem and mine is a 98. The dealer told me to ride it on the second D when I'm driving around the neighborhood....the swith it to the first D when on the highway.....the second D, which I think is D3, goes to about 40, then the RPM's start going crazy....at that point you need to switch gears.......hope this helps....
Old Apr 18, 2002 | 02:29 PM
hougee's Avatar
kee-master
i think the ECU is adjusted to grandma style driving... if u floor u car all the time for couple of of weeks.. the ecu should adjust and it should shift at higher rpms...
hg
Old Apr 18, 2002 | 03:12 PM
AtlCl's Avatar
Not AtlCl98 or Atl-CL
Get a venom, it should probably take care of that.
Old Apr 18, 2002 | 03:36 PM
Ricka220's Avatar
Trans
HG,
I ride it hard often and it shifts just the way it should, but when I just want to drive nice and easy, it seems like the trans always wants to keep a higher gear than is ideal. Adding some throttle just makes it downshift which is annoying. I don't think that the fuzzy logic is using grandma mode in my case, unless I need to disconnect the battery terminal to reset something from the previous driver.
Atlcl,
What would a Venom do for me?
Thanks for the responses.
Rick
Old Apr 18, 2002 | 05:33 PM
hougee's Avatar
kee-master
Re: Trans
umm... u r right... when u do drive nice and easy.. it does shift at lower rpm.. but that's how it is suppose to function tho... the car wants you to drive it hard!
i don't know... try resetting ur ECU and train it from the start... my car shifts after 3500 if i tap on the gas just alittle bit more...
hg
Originally posted by Ricka220
HG,
Atlcl,
Rick
Old Apr 19, 2002 | 01:01 PM
cldriver's Avatar
I understand what you are talking about and is not just specific to our CL's, its just the way honda/acura auto trannies work.
Like everyone said, if you're driving in city traffic with lots of stop-n-go, just leave it id (D3), when you get on the highway, put it in (D4). I guess its some kind of gas saving AT logic. If you look in your Owner's Manual (who da hell does that nowadays ), it also recommends D3 for city driving.
You can also get the Venom-400 which will quicken the shift to a lower gear among other things it does.
Old Apr 19, 2002 | 01:51 PM
99CL2.3's Avatar
Just my opinion: The Venom will not change the way your tranny shifts. I don't have an auto, so I don't know exactly what your problem is, but it seems like you are having "problems" that every automatic trans has if you let it shift itself. That's why a lot of people prefer stick because you have total control over your up/down shifts.
Old Apr 19, 2002 | 08:48 PM
JLai's Avatar
Cause stock sux.
Venom does cahnge the shifts. But only when activated. It doesn't activate till mid throttle or above. Thus...if your just cruising, it doesn't help that much. Also a pain in the ass if you live near hills.
Mike Pilipenko
Mar 26, 2024 09:21 PM
SidhuSaaB
May 30, 2020 12:40 AM
joflewbyu2
Oct 8, 2015 11:16 AM
mellsonnj
Sep 24, 2015 04:42 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
