TIME Correction Lengths for the 1st GEN
well i was going to angle all the speakers at the passenger in the front seat the farthest from them.. will this acheive the same thing, and then moderate TC for the front speakers... is it worth putting a 3 way component set in the rear deck?
don't even bother with the time alignment unless you have near perfect speaker placement already. the front stage should sound good on both the driver and passenger side. i've spent hours building kickpanels and still can't get a good stage. it's decent but not where i want it to be.
i advise only to use time alignment when everything else is straight.
i was really hoping for proaudio's opinion here.
but thanks for the input...
i find it hard to believe that rear speakers are ony to fill in the blank space bak there, but thats why i ask questions
i have 693.5i's in the rear, and do make a noticeable difference when I fade to front and then fade it back on...I just measured and used the time correction, the alteration doesn't sound that much different then before I did it
As far as the time alignment goes - everything should be adjusted based on the driver that is furthest away. Now, furthest away can mean in time as well as physical displacement. You need some $$$ anaysis software like Smaart to see this. Otherwise, general delaying can make a world of difference in the clarity of a system. 1ft is generally 1ms, although it really alters with freq.
sorry for the bumping the old thread
i was trying to set it up and i don't think i'm doing it right.
here are my measurements
LF RF
36" 54"
LR RR
56" 61"
the measurement i got for the LF comes out to be 1.85. but i'm not too sure how to do the rest.
can anyone help me out?
LF RF
36" 54"
LR RR
56" 61"
orkoTL
4G TL Problems & Fixes
107
Sep 28, 2017 09:12 AM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
