tech. question (mirrors/heated seats)
Old Aug 18, 2004 | 02:52 PM
b16-to-j30a1's Avatar
I have searched for this question but found no luck.... I have a 97 3.0... My power mirrors, and heated seats are not working. Might have gone out at same time. I checked all connections and they are tight. I checked all fuses, both under hood and drivers side floor box. All fuses are good. I guess my question is; are the two related in one relay under the hood? Or are these just two unrelated deaths of electronics. Any help would be appreciated......
Old Aug 18, 2004 | 03:35 PM
Hobo's Avatar
Flap.
did you visually inspect the fuses? or use a fuse tester?
Old Aug 18, 2004 | 03:41 PM
I actually replaced the 15 amp under the hood and the 7.5 by the dead pedal.
Old Aug 18, 2004 | 04:15 PM
fusionnv's Avatar
Gimmie my points Biatch!
Do the switches light up? On my friends heated seats, they were just unplugged.
Old Aug 18, 2004 | 08:08 PM
the switches do not light up... and they did work/ light up when I bought the car.
Old Aug 18, 2004 | 08:21 PM
legendaryCL98's Avatar
'07 November = STI
when did u buy the car? maybe... try calling up the dealer?
... maybe a wire got disconnected... did u go through any DIY lately?
Old Aug 18, 2004 | 10:42 PM
fusionnv's Avatar
Next step is to see if there is power going thru the fuse (Even though it is not broken). Since there is no power from the switch to the fuse and switch to seat.
Old Aug 19, 2004 | 03:13 AM
correction.... seat heaters light up when lights are on, but not when pressed on. That tells me connections are good. Still wondering if the two are related (heaters and mirrors)?
Old Aug 19, 2004 | 07:25 AM
fusionnv's Avatar
Cool that is good. Hmm but this is kinda difficult. Did you do any changes to the car beforehand like change simple things like a light bulb. I had a friend also that he put in 100 watt bulbs in the headlights and they would cause the dash light fuse to keep blowing out. Very strange those ford cars. That took the mechanics at ford 6 months to figure out.
Old Aug 19, 2004 | 04:12 PM
Funny you say that, I installed a cd player, HID headlights, and replaced the window regulator and switch. I thought this happenned after the window regulator, but I checked all my connections and they seem good...... I am really just trying to fix the little stuff on this car before I sell it, so if I never figure it out, I guess I won't lose any sleep..
Old Aug 21, 2004 | 03:49 AM
thanks for the help so far...... any other opinions?
Old Aug 21, 2004 | 07:46 AM
chrismc101's Avatar
7th Gear
Heated Seat Switch & Rear Defrost
I'm kinda piggy backing off this original post. My driver side heat seat switch don't light up nor warm up. Now that you mention it, I will check fuse today. But my rear defrost doesn't work for some reason. When pressed, the defrost ligt will light up, but don't defrost. What does that sound like or what does that mean? Hope it doesn't mean I gotta replace glass in the back.
But my heated seat switch does not light up at all. Hope you guys/girls can help me and shed some light on these things in front of me. I thank all of you in advance for your time & efforts to respond.
GreenCL3.0
aka
AcNickulous
Old Aug 23, 2004 | 11:56 PM
anyone????
BoricuaTL
Apr 8, 2016 01:08 PM
bailey24
Nov 21, 2015 08:43 PM
heykosal
1G RDX Problems & Fixes
Sep 21, 2015 09:41 AM
d.lim
Sep 15, 2015 08:54 PM
datadr
Sep 12, 2015 09:12 PM
