sub noise
Old 01-28-2004, 11:45 AM
Promiscious Boy
JetBlackAcuraCl's Avatar
sub noise
why do i get this constant boom after i turn my car off, but leave my amp on. this never happened before. its like the sub is making a constant boom, but then when i shut the switch off, it goes off.
Old 01-28-2004, 11:49 AM
Slooo97CL's Avatar
ground, gone bad.
Old 01-28-2004, 01:05 PM
You Fawkin Kiddin Me!
Casper98CL's Avatar
leaving the amp (radio) on when you shut you car off is NOT good for a sub. You havea sub with stock system?! I had that set up and had same issue.. its the feedback off current... no initial harm but constantly doing it will fry your coils
Old 01-28-2004, 01:15 PM
The movement has started
baka_t's Avatar
Stock system?? Best bet is to put the sub amp on a switch. If your good with electronics you could rig up a relay to turn it off/on.
Old 01-28-2004, 05:22 PM
Promiscious Boy
i do have a switch to turn the amp on and off...its just when i turn my car off after playing music and dont turn the switch off, i get this real woofing feedback and it doesnt stop until i turn it off...it never used to do this until i unplugged everything and put in a new ported bandpass box
Old 01-28-2004, 08:09 PM
wilp99's Avatar
my bandpass does it too. i got a kenwood deck. doubt its the box but, i think its the internal powersupply in the amp, discharging kind of like a capasitor. hell i dont know im just talkin out of my ass.
Old 01-29-2004, 02:01 PM
Acura2.3CL's Avatar
I used to get the same thing. I found out that when I turn the "bass boost" control knob down it goes away. I am running off of the stock 99 2.3CL system (no new headunit ro anything). It was a pain to install but works just fine. I had to get an adapter to splice into the part of the wiring harness that goes to the back of the CD player. This was for the remote wire, which turns the amp off when either the headunit is off or the car is off. I also had to get another adapter which spliced into the back speakers for the RCA plugs. If you have a control knob try tunring it down before you turn the car off.
Old 01-29-2004, 07:10 PM
Mike 350Z's Avatar
lol...you don't need to be good with electronics to do this....all i did was cut the turn-on lead wire in half and twist each end around a prong on the switch
Old 01-30-2004, 10:09 AM
Kiljaedoen's Avatar
ever heard of a remote wire?
MrHeeltoe
20
02-23-2023 01:54 PM
SexyRL
4G TL Problems & Fixes
08-19-2016 10:03 PM
xsilverhawkx
10-05-2015 11:00 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
Quick Reply: sub noise
