stereo help (revisited)
hey guys im hooking a sub and amp obviously up to a stock deck. i need to know what wire is the accessory so i can hook my remote up to it. does anyone have their chiltons manual to look it up or possibly a online wire harness cheat sheet. thanks doods
Acura CL Head Unit Terminal
I just installed an amp in my CL this past week and I needed the same info...using the above diagram I tapped into "A5- White/Red". The amp will power when you turn the key to accessory.
Good luck!
Good luck!
Originally Posted by Mulk
an easier alternative if you're interested is to tap into the cig ligher wire, it comes on when the key is turned to ACC also.
There is a remote wire for the stock amp (if it's bose premium) if not, the cig wire would work, it's on the same fuse as the radio
lol yeah i figured since he's keepin the stock head unit, he may not wanna cut/splice wires that are behind the stock connector in case anything gets messed up; plus they're a pain to work with since you dont have much extra slack
4drviper
Apr 23, 2025 07:13 PM
snorf
Nov 4, 2019 06:44 AM
ivegotthenav
Sep 11, 2015 07:51 PM
Gianni Formica
Sep 7, 2015 08:28 PM
