Springs rubbing with tire!! help!
ok.. everytime i go over speed bumb my i hear this grinding sound... i took off my rear tire and and found out that it is probably my springs rubbing against the inner side of the tire...
ok.. i have 205/55 R16... their stock sized on stock rims!! i don't know what to do... help!!
My Home Planet
It's rubbing without a drop???
That can't be. I don't think it would make a grinding sound if it was the tire. Do you notice any abnormal wear on the inner portion of the tire? Something's loose or broken. Check your hub.
Work safe avatar bish :D
btw: the tires would not rub against the springs them selves. they would rub agaisnt the control arm.
i just double checked... ya itz the inner sides of my tire rubbing the springs... for some reason these tires are extra fat ... like it sticks out more like a off road tire than normal tires of itz size... my front has different tires with same size and itz fine....
problem SOLVED..............
swap the tires
its just that brand he got a bet....my nuespeed and kyb set with stock tires is fine..
Casper, thanks for those stock shocks and spring....but i decided to keep my car and took those coil-over off and replace it with nuespeed.
1fatcrxnem1
22
06-01-2018 01:23 AM
DunesCreations
09-09-2015 12:03 PM
