slight surging while breaking?
ok, i've noticed for the past few months that when i am breaking and am under 20 mph, if I keep the break pedal depressed the same amount there is a slight surging of the breaking. Like I am lightly pumping the breaks. Kinda weird.
I have rotora slotted rotors and axxis organic pads. I have several ideas of what it could be. Either teh ABS motor is jacked so it's not breaking properly, i have a warped rotor (I better not dammit, they're not even a year old), or it has something to do with the slots in the rotors, and is normal.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by knothd
Did u break those in b/4 gettin after it with some hard breaking??
yep, I changed out the entire break system at once, then I found one of the rotora's to be warped right out of the box. Took them a month to replace it.
so I definitely did the break in process when I got the replacement. PRobably just the damn hills around here, or I splashed into a puddle of melting snow after I did some hard breaking. I'm just gonna go with some OEM replacements after this.
You should just get slotted not cross-drilled. The cross-drills are really only good for circuit racing... But the slotts will vent the gasses without getting wash-baithed and warped from rappid temporature changes due to water puddles.
emailnatec
29
09-28-2018 04:27 PM
xsilverhawkx
09-28-2015 06:51 PM
4drviper
09-23-2015 09:00 PM
