slight surging while breaking?
Old Mar 6, 2006 | 02:11 PM
ghost_masterCL's Avatar
ok, i've noticed for the past few months that when i am breaking and am under 20 mph, if I keep the break pedal depressed the same amount there is a slight surging of the breaking. Like I am lightly pumping the breaks. Kinda weird.
I have rotora slotted rotors and axxis organic pads. I have several ideas of what it could be. Either teh ABS motor is jacked so it's not breaking properly, i have a warped rotor (I better not dammit, they're not even a year old), or it has something to do with the slots in the rotors, and is normal.
Old Mar 6, 2006 | 02:13 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Sounds like a warped rotor, or your brake fluid is low
Old Mar 6, 2006 | 02:54 PM
goddamit, if it is a warped rotor, then fuck rotoras
Old Mar 6, 2006 | 03:09 PM
knothd's Avatar
Did u break those in b/4 gettin after it with some hard breaking??
Old Mar 6, 2006 | 03:24 PM
(Mid-Atlantic)
Did you do the bed-in process first of all? I bedded mine in and they warped after 6 months cuz of all the goddamn hills around here Brembo's are next
Old Mar 6, 2006 | 04:02 PM
ib_jimmy's Avatar
did u change out the pads the same time u put in the new rotors?
Old Mar 6, 2006 | 05:23 PM
yep, I changed out the entire break system at once, then I found one of the rotora's to be warped right out of the box. Took them a month to replace it.
so I definitely did the break in process when I got the replacement. PRobably just the damn hills around here, or I splashed into a puddle of melting snow after I did some hard breaking. I'm just gonna go with some OEM replacements after this.
Old Mar 6, 2006 | 07:51 PM
ajtcl's Avatar
Peace, Love & Acura
You should just get slotted not cross-drilled. The cross-drills are really only good for circuit racing... But the slotts will vent the gasses without getting wash-baithed and warped from rappid temporature changes due to water puddles.
Old Mar 6, 2006 | 09:54 PM
they are only slotted.
Old Mar 6, 2006 | 10:39 PM
agranado's Avatar
how handsome I am
does it feel like the brakes kick back when you get to around 10'ish mph too? Just wondering... mine do these all the time.
4drviper
Apr 23, 2025 07:13 PM
hashbrown
Feb 18, 2022 11:20 AM
emailnatec
29
Sep 28, 2018 04:27 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
