shock problem
Old Sep 9, 2003 | 01:27 PM
Decimate157's Avatar
shock problem
aight when i turn the steering wheel i hear a noise that sounds like 2 metals cracking. it sucks. and when i step out of the car and when my weight comes off it, you can also hear it. what could it be, what should i do. the shock is not leacking or anythign but i think thats what it is, shock or struct or something. was good fellas!!!!!
Old Sep 9, 2003 | 01:34 PM
Slooo97CL's Avatar
have you dropped or lowered your car? how many miles....run your vin for a ball joint check up....
could be anything though....
any noise when coming to a stop...or turning the wheel when you arent moving?
Old Sep 9, 2003 | 03:06 PM
r3mix3r's Avatar
hmmm when i get out of the car i hear same thing... coming from front passenger side wheel well
Old Sep 9, 2003 | 03:08 PM
r3mix3r's Avatar
when going slow in parking lots i hear Creeking noise every 2 seconds pretty damn loud and when i turn hard in park i hear clunk clunk clunk
Old Sep 9, 2003 | 06:30 PM
athlonxp's Avatar
Hey rodxx,
It was the camber kit for me. I've been messing around with it and so took a can of silicone spray and sprayed directly into the rubber bushings. OK, that worked for a few hours but when it dried back to the sqeaks again. The clunk I still haven't figured out yet but hopefully I'll find it.
Anyhow, take the camber kit off and put some heavy grease through them and see if that helps. Also, this might be a risk and add more to the clunk but loosen the 4 horizontal anchor bolts a bit loosening up the rubber bushings. I believe the real cause may be that the bushings are rubbing up against the control arm and therefore you get the squeak squeak no matter what. And spraying a lubricant may simply aid a bit but after a little bit, since it's rubbing the spray may dry off and it squeaks again.
My point is it's the friggin' camber kit. Have to move on to the ball joint type folks. Like the following:
or
Peace.
Old Sep 10, 2003 | 08:31 AM
wingman's Avatar
Old Man
When I had my front Ingalls camber kit installed, the inner fender interferred with the movement of the suspension. The ball joint (not really the ball joint but the upper arm where the ball joint mounts) contacted the inner fender and need to be cut and pounded (the inner fender, not the ball joint). A tell tail sign is shinny metal where the upper-arm is contacting. This may solve the clunking noise that some of you are noticing.
As for the squeeking and the creaking... I'm still trying to figure mine out...I though the rubber bushing versions weren't going to squeek?
Old Sep 10, 2003 | 11:46 AM
Sacramento CL's Avatar
A-CL Member
I've had a low-speed squeak ever since I installed my springs & struts. I'm guessing it's the seat where the bottom of the spring sits. I'm gonna spray the shit out of that area with some lithium grease to see if it fixes the noise.
Old Sep 10, 2003 | 07:20 PM
suXor's Avatar
Still trolling
Mine was the camber kit too. Offset pivot mounts. The poly bushings for the upper A arm squeaked.
Old Sep 10, 2003 | 07:48 PM
athlonxp's Avatar
Hey folks,
I had a major consistant squeak in my right rear KYB AGX shock since Monday, after my car dropped from about a foot high when my car jack suddenly collapsed.
I don't know if this fast drop caused damaged to the shock but I believe it is now blown. So all I'm saying is, and I think someone else mentioned, that it may just as well be the shock. Have it checked out. It's sorta embarassing when everyone looks at you because of the squeaks, if you know what I mean!!!
If it's not the shock I'm still sticking to the theory that it's the camber kit bushings.
Until next time. I'll do some more meticulous investigation and keep you all updated!!!
-James
Old Sep 12, 2003 | 08:42 AM
WineRed2.2CL's Avatar
Old School Ridin Clean
I like the progress we are getting, so we've come to a conclusion that it is the Camber kit. I have ingalls intalled, and on my right front side is where the noise is coming from i hate it. I'll try that grease thing.
I was thinking of just bring my car in to a Suspension Specialist here in MIami and they do there own camber kit by welding. I was hesitant because i wanted the option of raising the car again, but every one with lowered cars goes to them. Ferrari's, Mercedes thats been lowered. So ima think of doing that.
Old Sep 12, 2003 | 08:59 AM
dulux's Avatar
are you talking about miami chassis?
Old Sep 12, 2003 | 01:52 PM
r3mix3r's Avatar
ya dude only my front right camber makes noise also!! I knew it was that because it didnt fit when the guy installed it and has to weld off some of the control arm and it still does it i would luv to fix it!
Old Sep 15, 2003 | 02:16 PM
yeah Miami Chassis is the place.
Old Sep 15, 2003 | 02:22 PM
dulux's Avatar
Miami Chassis doesnt weld on our cars, they fix camber issues without welding.
Old Sep 15, 2003 | 06:35 PM
A-CL Member
Well, I sprayed the hell out of my squeaky spring/strut w/ lithium grease last night and it didn't help. In fact, my squeak is starting to get worse. I don't have a camber kit so it can't be that... I guess it's time to take it into the shop. Oh well.
Old Sep 17, 2003 | 11:23 AM
A-CL Member
Hey - my last post was a little premature. The squeaking went away after two days of driving. If you're squeaking, buy some lithium grease and spray that stuff where the springs sit on the struts. It comes in a spray can w/ a straw like WD-40, so you can direct the spray pretty well.
Old Sep 17, 2003 | 11:49 AM
wingman's Avatar
Old Man
You need to becareful in what you spray. Some lubes are not compatable with rubber (stock bushings)... it will eat up the material in the near future.
Old Sep 17, 2003 | 12:03 PM
dulux's Avatar
i use silicon, grease eats rubber.
SidhuSaaB
May 30, 2020 12:40 AM
IIDXholic
3G RLX (2013+)
23
Oct 19, 2015 09:40 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
4drviper
Sep 23, 2015 07:42 PM
