reverse light
Old Jun 23, 2006 | 05:55 PM
blueCL's Avatar
Need For 6 Speed
reverse light
what size are the reverse lights on a 99 3.0....i'm looking for blue reverse lights
Old Jun 23, 2006 | 06:04 PM
blueCL's Avatar
Need For 6 Speed
i mean the reverse bulbs
Old Jun 23, 2006 | 06:25 PM
Slooo97CL's Avatar
Light bulb sizes
1997-1999 ACURA CL
Low beam headlamp | 9006
High beam headlamp | 9005
Front corners | 168/194
Rear corners| 168/194
Front turn signal | 7440
Rear turn signal | 1157
Tail light |1157
High mount stop light | 7440
License plate | 168
Back up light | 1156
Glove box | 3021
Map light |168/194 | 3021 (97’s)
Dome light | DE3910
Door light | DE3021
Trunk/Cargo area | 3021
directly from the noob guide that no one uses
Old Jun 23, 2006 | 07:22 PM
SupraManAG's Avatar
One custom CL
Old Jun 23, 2006 | 09:32 PM
blueCL's Avatar
Need For 6 Speed
haha thanks my bad for not looking
Old Jun 23, 2006 | 09:43 PM
subbuzz's Avatar
07 tl-s in
Old Jun 23, 2006 | 10:41 PM
blueCL's Avatar
Need For 6 Speed
just bought some back up lights on ebay but i cant find to see DE3910 dome lights and was wondering if DE3175 lights would fit.
Old Jun 23, 2006 | 10:49 PM
blueCL's Avatar
Need For 6 Speed
okay i searched and it said the dome light for the 99 cl its DE3022
Old Jun 24, 2006 | 10:27 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Originally Posted by SupraManAG
Old Jun 24, 2006 | 10:37 PM
Musulsa's Avatar
Korean FIYAH!
DE3022 is what every guide online says, but if you check your stock bulb, you'll find that it is quite a bit longer than DE3022.
The first 2 digits in the DExxyy "festoon" style bulbs refer the to the length in mm.
So DE3022 is 30mm long. DE3910 is 39mm long. The stock Acura dome bulb is 39mm long, hence the guide recommending DE3910 over the DE3022. DE 3022 will work. Actually any festoon bulb between DE30xx to DE39xx will work.
Don't focus too much on the model number, focus more on the length. There are actually many different festoon style bulbs that will fit.
If you are looking for an LED dome bulb check http://autolumination.com/festoon.htm
I have the 9-led 39mm blue led dome bulb and I love it. I also occasionally switch it out for a 9-led 39mm hyperwhite led dome bulb when I get bored of blue. Both are incredibly bright and eye catching.
Old Jun 25, 2006 | 12:42 AM
klepto's Avatar
motherfucking
rockyboy
Aug 4, 2024 10:35 AM
Yikes
May 3, 2021 04:29 PM
Soul_Deamon
4G TL Problems & Fixes
Nov 2, 2015 04:32 PM
Mcj270
Aug 31, 2015 04:45 PM
