reverse light
Light bulb sizes
1997-1999 ACURA CL
Low beam headlamp | 9006
High beam headlamp | 9005
Front corners | 168/194
Rear corners| 168/194
Front turn signal | 7440
Rear turn signal | 1157
Tail light |1157
High mount stop light | 7440
License plate | 168
Back up light | 1156
Glove box | 3021
Map light |168/194 | 3021 (97’s)
Dome light | DE3910
Door light | DE3021
Trunk/Cargo area | 3021
directly from the noob guide that no one uses
1997-1999 ACURA CL
Tail light |1157
License plate | 168
Glove box | 3021
Dome light | DE3910
Door light | DE3021
Need For 6 Speed
just bought some back up lights on ebay but i cant find to see DE3910 dome lights and was wondering if DE3175 lights would fit.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by SupraManAG
Korean FIYAH!
Originally Posted by blueCL
okay i searched and it said the dome light for the 99 cl its DE3022
The first 2 digits in the DExxyy "festoon" style bulbs refer the to the length in mm.
So DE3022 is 30mm long. DE3910 is 39mm long. The stock Acura dome bulb is 39mm long, hence the guide recommending DE3910 over the DE3022. DE 3022 will work. Actually any festoon bulb between DE30xx to DE39xx will work.
Don't focus too much on the model number, focus more on the length. There are actually many different festoon style bulbs that will fit.
If you are looking for an LED dome bulb check http://autolumination.com/festoon.htm
I have the 9-led 39mm blue led dome bulb and I love it. I also occasionally switch it out for a 9-led 39mm hyperwhite led dome bulb when I get bored of blue. Both are incredibly bright and eye catching.
rockyboy
08-04-2024 10:35 AM
rockyboy
01-25-2016 06:00 PM
Soul_Deamon
4G TL Problems & Fixes
11-02-2015 04:32 PM
