Removing climate control...
Old Oct 8, 2006 | 12:37 AM
Sleep_DEPRIVED_Sleeper's Avatar
Turtle Charged, Biotcch!!
Angry Removing climate control...
Well, after over 30 mins of searching and reading, i still haven't found a way to remove the climate control for a 97 3.0...so i decided to find a way myself...i removed the clock/trim and the head unit (i love the 97's interior, everything just pops out like legos...)
But 20 mins + after removing the head unit, i just managed to remove the 2 bolts directly under the climate control...i was afraid that the wood trim would snap so i stopped prying...
In the end i couldn't do what i wanted to do...can anyone give me instructions on how to remove the climate control assembly?? Thanks...
ZZZ
Old Oct 8, 2006 | 05:08 AM
NitiNiteZ's Avatar
The Hefty 2.2
just curious of why u would want to remove the climate control? If u wanna control the air by clicks... or low/med/high settings... turn auto on... then hit the Fan button... and go up from there.
Old Oct 8, 2006 | 04:31 PM
sixfifty's Avatar
I
i think he might be trying to change the output color of the temperature/other things on the screen
Old Oct 8, 2006 | 04:57 PM
herbalist's Avatar
chips and smokes, lets go
check this thread. i managed to remove the climate control when i was wrapping my wood grain. its a mission.
http://www.acura-cl.com/forums/showt...ght=WOOD+GRAIN
Old Oct 8, 2006 | 08:16 PM
teh CL's Avatar
what colour did you wrap ur woodgrain with?
Old Oct 8, 2006 | 10:21 PM
herbalist's Avatar
black pleather
Old Oct 9, 2006 | 09:00 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Originally Posted by herbalist
black pleather
Pics?
Old Oct 9, 2006 | 12:12 PM
teh CL's Avatar
Old Oct 9, 2006 | 01:31 PM
hornyleprechaun's Avatar
Bent = #1
http://www.auburn.edu/~dupcatj/woodgrain.htm
Try that tutorial that I constructed.. Send me a PM if you need any help (best way for me to respond to you). You need to remove all that stuff to get the woodgrain removed.. I am almost 99% positive that you need the woodgrain removed before you can take the climate control out because I think there are two screws for the climate control.
Be warned though that the woodgrain will more than likely crack unless you take very very careful measures not to break it. It can be removed without cracking it, but take your time.
Good Luck.
Old Oct 9, 2006 | 01:33 PM
ib_jimmy's Avatar
good luck.
Old Oct 12, 2006 | 07:00 PM
herbalist's Avatar
Pics?
this is an old pic i took with my camera phone
Old Oct 12, 2006 | 08:58 PM
melo72's Avatar
I just used this thread to change the bulbs in my 98 3.0. The only difference are the location of the screws. There should be one under the woodgrain on the right side of the glove compartment. The other 2 are located under the AC. All of the clips are in the right location.
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
dainmezron
Oct 16, 2015 06:56 PM
CWOVette
1/2G MDX (2001-2013)
Sep 27, 2015 02:29 AM
lowgrowl
Sep 26, 2015 05:18 PM
